That's my question...
I have a text field named "Email Address" which value is taken from a XML. It looks like:
Email address: example@ex.com
I need a "Send email" button that sends the email :
- In PDF form format (Not in XML data)
- To the address specified in "Email Address" text field, NOT to a fixed email address.
Is this possible?
Solved! Go to Solution.
Views
Total Likes
Check the sample below..I am taking the Email address, Subject and Message from the input fields on the form.
https://acrobat.com/#d=pFyQRZ*C1TYAlU*8VOpV8A
To send the PDF as an attachment, you need to change your settings as below.
Srini
Views
Total Likes
Srini
Views
Total Likes
Paul has a sample on the forum: Re: Variable E-mails in the e-mail button function
Also samples here:
https://acrobat.com/#d=aZcLnjbnm47P-abdU*oC9Q
https://acrobat.com/#d=0T85TMIsVEJd4XKsPLq7Fg
Hope that helps,
Niall
Thank you both!
The two answers were correct but I only could give a vote.
I'm been reading here too: http://www.acrobatusers.com/tutorials/dynamically-setting-submit-e-mail-address (Acroform way
Anyway, I like Srini explained way.
Thanks !!!
Views
Total Likes
