3 Replies Latest reply on Apr 4, 2010 3:30 PM by the_wine_snob
    Exporting Quicktime .mov with audio
    Michael5188
      I searched for a solution to my problem for a while and haven't found any so I felt I'd finally ask.
      I am exporting a movie in Premiere Pro 2.0 as a .mov.  Yet everytime I export the audio quality is awful. The audio plays fine within premiere, and the video exports perfectly.  I've tried uncompressed audio, and the result is a loud static sound.  I've tried multiple compressors (oblivious to which I should be using) none of which offered good results (sometimes it was even silent).  What settings should I be using?  (By the way, the audio in the scene is .mp3 and .wav, but I felt using the uncompressed setting would be find since I wouldn't be recompressing the audio)
      I'm sure this is a very basic issue that has been addressed multiple times, but I couldn't find a thread or resource on the internet that helped with this issue I'm having. Thank you for any help you can offer, I appreciate it.
        • 1. Re: Exporting Quicktime .mov with audio
          the_wine_snob Level 9
          I use the same settings, as you, with one exception - instead of 8-bit, choose 16-bit for the Sample Depth.
          I also dislike using MP3 as a source. With the exception of tiny SFX files, I always convert these to PCM/WAV (Uncompressed) 48KHz 16-bit, before Import. That does NOT restore all the data lost with the MP3 compression (I hate the sound with MP3, but that's a different topic), but it gives me the best source to edit. I use Adobe Audition, but the free Audacity does a great job of this.
          Hope that the 16-bit does the trick for you.
          BTW - what are you using to play the resulting MOV?
          • 2. Re: Exporting Quicktime .mov with audio
            Michael5188 Level 1
            Thank you very much Bill, that did it.  I'm surprised at the difference it made.
            (I'm using Quicktime Pro to play the video)
            Thanks again.
            -Michael
            • 3. Re: Exporting Quicktime .mov with audio
              Michael,
              Glad that handled the situation, and thank you for reporting.
              I also use QT Pro 7.5.5, but the reason that I asked is that many users have recently had issues with the current 7.6.x series of QT Player. Since the Bit-depth helped, and you are not having other issues with PrPro, the version is probably moot.
