1 Reply Latest reply on Apr 4, 2010 3:45 PM by the_wine_snob
    Possible to map/export 4channels of Audio?
    sync2rhythm Level 1
      Does anyone know of a way to export a Video File w/4Channels of  Audio?
      (or a way to create the following)
      We need to deliver a Broadcast File (Quicktime) that has:
      Video Track
      Audio 1 = Left
      Audio 2 = Right
      Audio 3 = Music
      Audio 4 = Audio FX
      All Media is already separated on the tracks and the audio mix is the  way we want.
      To what format? Settings? Workflow?
      ____________________
      Apparently, this is really easy to do in FCP... so I can only imagine that I am overlooking something in PP CS4.
      www.geniusdv.com/weblog/archives/exporting_multiple_audio_tracks_with_quicktime.php
      Maybe the simplest way is to just Export from Vegas/Import to FCP/Export  to QT?
        • 1. Re: Possible to map/export 4channels of Audio?
          the_wine_snob Level 9
          One can Export as discrete Audio channels, with WMA, but I assume that you are looking for a muxed file, containing both the Audio & Video.
          I use WMA from my DD 5.1 SS Projects, to take into Audition, and re-mix for use in a DTS stream, as supplemental Audio stream on a DVD-Video, but that is different. I also Export my Video and my Audio as elemental/elementary streams, so the files are not muxed.
          There was a very similar post recently, and that OP needed to Export to tape. Do you also need to Export to tape?
          Good luck
