4 Replies Latest reply on Apr 5, 2010 7:33 AM by David_F57
    RadioButton Question
    choisington
      Why does this not work?
      public function getCategoryRadioButton(categoryNo:int):void
              if (categoryNo == 2)
                  governmentRadioButton.selected = true;
              else if (categoryNo == 3)
                  academicRadioButton.selected = true;
      OR THIS???
      public function emailBooleanSet(doNotEmail:String):void
              if (doNotEmail == 'n')
                  emailCheckBox.selected=true;
              else if (doNotEmail == 'y')
                  emailCheckBox.selected=false;
        • 1. Re: RadioButton Question
          choisington Level 1
          Ok well I figured out that you can reference the label of the radiobutton from the group name.
          Survey1.selectedValue = 'While browsing the website';
          But how is it done for a checkbox. This seems like an easy question, but I just can't figure it out.
          • 2. Re: RadioButton Question
            David_F57 Level 5
            http://gumbo.flashhub.net/radiocheck/ source enabled
            This may give you what you need - The logic assumes you are treating the checkbox like a radiobutton, you could always reskin a radiobutton if you wanted it to look like a checkbox.
            David
            • 3. Re: RadioButton Question
              choisington Level 1
              That does help, but I am still curious why it is saying "can not access propert of null object" My input that I pass in is not null, I checked by displaying it in an alert.
              This really is a mystery to me.
              • 4. Re: RadioButton Question
                David_F57 Level 5
                Maybe its the way the 'if' is done, possibly the better way would be to use a switch statement so that if there is a problem with the passed parameter it wouldn't break the code.
                switch(category)
                case 0: rb1.selected = true;
                case 1: rb2.selected = true;
                case 2: rb3.selected = true;
                case 3: rb4.selected = true;
                just a thought
                David.
                [edit] also for the other if statement i would do it this way
                if (noemail=='n')  checkbox=true else checkbox=false;
