21 Replies Latest reply on Apr 11, 2010 4:51 PM by Halmeister
    Premiere Elements 8 problems
    26.2morgan
      I just bought a new computer along with a new Canon Vixia HF20 HD camcorder and premiere elements 8. The software has been a problem since new. It freezes and when trying to edit video, the preview window is so choppy, you can't edit. I installed the update pre 8.0.1. and updated my video card. Now it won't even finish a burn. I get a blue screen or my computer just restarts. everything else runs fine on the computer. I'm attaching my computer specs.
      Please help. Scott
        • 1. Re: Premiere Elements 8 problems
          1 hard drive is never going to work to edit HD
          What I am going to build later this year is near the top of my notes page... with 3 hard drives
          http://www.pacifier.com/~jtsmith/ADOBE.HTM
          Also, go to the SEARCH FORUMS box to the right & up, and enter
          Canon HF20
          and
          AVCHD
          Read all the other discussions
          • 2. Re: Premiere Elements 8 problems
            the_wine_snob Level 9
            I agree with John T., that a single HDD is never going to give you good performance. Many recommend 2 physical 7200 RPM min HDD's, and I personally think that 3x should be the minimum in this general config.
            C:\ OS, programs and probably Page File
            D:\ Project and Scratch Disks
            E:\ Media - note: for HD, this could well be a RAID in one of the 0 configs.
            Now, BSOD's are most often hardware related. Things to look at are:
            1.) heat buildup, especially in the CPU
            2.) RAM - is one stick going bad?
            3.) power supply - is it failing, or are the voltages per rail off?
            4.) MoBo - bad soldered joints can go bad from mechanical, or heat wear
            The tools, linked in this ARTICLE can help you. SpeedFan would be my very first stop.
            This ARTICLE might give you tips on finding out what is going on with your computer, just before and during the crashes.
            I'd also set up the OS to NOT reboot on error, as the info on that BSOD might yield some clues too.
            • 3. Re: Premiere Elements 8 problems
              Halmeister Level 1
              Me too.
              Intel Quad CPU, 8G RAM, Velociraptor 10K RPM HDD1, 1.5 TB HDD2
              Windows 7-64
              This is my first try with Premier Elements.
              Crash, Crash, Crash.
              CC Cleaner, etc.
              What is the deal here?
              Google it:
              Results 1 - 10  of about 247,000 for adobe premiere elements 8 crashes
              247,000 results for adobe premiere elements crashes.
              That's a lot of uninstall / reinstall.
              • 4. Re: Premiere Elements 8 problems
                Welcome to the forum.
                Now, would you care to post your problems, your system, your Project Presets and your Assets' full details?
                If so, you might want to read this ARTICLE to help us help you. It covers the types of info that will be so useful. If you are not looking for solutions, then that will be fine too.
                • 5. Re: Premiere Elements 8 problems
                  Halmeister Level 1
                  Thanks for being willing to help!
                  It just crashes after loading. I can't do anything.
                  Computer
                  Model : HP-Pavilion KQ497AAR-ABA m9340f
                  Workgroup :
                  Host Name :
                  User :
                  Processor
                  Model : Intel(R) Core(TM)2 Quad CPU    Q6700  @ 2.66GHz
                  Speed : 2.67GHz
                  Cores per Processor : 4 Unit(s)
                  Threads per Core : 1 Unit(s)
                  Type : Quad-Core
                  Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
                  L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
                  Computer
                  Mainboard : PEGATRON CORPORATION Benicia
                  BIOS : American Megatrends Inc. 5.35 12/16/2008
                  Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
                  Multi-Processor (MP) Support : No
                  Multi-Processor Advanced PIC (APIC) : Yes
                  Total Memory : 8GB DIMM DDR2 DDR3
                  Chipset
                  Model : HP P35/G33/G31 Processor to I/O Controller
                  Front Side Bus Speed : 4x 267MHz (1GHz)
                  Memory Bus Speed : 2x 401MHz (802MHz)
                  Memory Module(s)
                  Memory Module : Samsung M3 78T5663QZ3-CF7 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
                  Memory Module : Avant Tech 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
                  Video System
                  Video Adapter : NVIDIA GeForce 9500 GS (32 SM4.0 1.4GHz, 512MB DDR2 2x500MHz, PCIe 1.00 x16)
                  Graphics Processor
                  Adapter : NVIDIA GeForce 9500 GS (32SP 1.38GHz, 512MB 2x500MHz)
                  Storage Devices
                  WDC WD3000HLFS-01G6U0 (300GB, SATA300, 10000rpm, NCQ, 16MB Cache) : 279GB (C:) (E:)
                  ST31500541AS (1.5TB, SATA300, 3.5", 5900rpm, NCQ) : 1TB (G:)
                  Generic USB SD Reader (USB) : N/A (F:)
                  Generic USB CF Reader (USB) : N/A (H:)
                  Generic USB xD/SM Reader (USB) : N/A (J:)
                  Generic USB MS Reader (USB) : N/A (K:)
                  TSSTcorp CDDVDW TS-H653Q (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
                  Logical Storage Devices
                  System Reserved (E:) : 100MB (NTFS) @ WDC WD3000HLFS-01G6U0 (300GB, SATA300, 10000rpm, NCQ, 16MB Cache)
                  1.5 TB  (G:) : 1TB (NTFS) @ ST31500541AS (1.5TB, SATA300, 3.5", 5900rpm, NCQ)
                  Hard Disk (C:) : 279GB (NTFS) @ WDC WD3000HLFS-01G6U0 (300GB, SATA300, 10000rpm, NCQ, 16MB Cache)
                  Removable Drive (F:) : N/A @ Generic USB SD Reader (USB)
                  Removable Drive (H:) : N/A @ Generic USB CF Reader (USB)
                  Removable Drive (J:) : N/A @ Generic USB xD/SM Reader (USB)
                  Removable Drive (K:) : N/A @ Generic USB MS Reader (USB)
                  Optical Drive (D:) : N/A @ TSSTcorp CDDVDW TS-H653Q (SATA150, DVD+-RW, CD-RW, 2MB Cache)
                  Peripherals
                  LPC Hub Controller 1 : HP (ICH9) LPC Interface Controller
                  LPC Legacy Controller 1 : Asus F8000
                  Audio Device : ASUS Virtuoso 100 (Xonar D1)
                  Audio Codec : Gammagraphx 0000h
                  Serial Port(s) : 2
                  Disk Controller : HP ICH8R (ICH8) SATA RAID Controller
                  USB Controller 1 : HP (ICH9) USB Universal Host Controller
                  USB Controller 2 : HP (ICH9) USB Universal Host Controller
                  USB Controller 3 : HP (ICH9) USB2 Enhanced Host Controller
                  USB Controller 4 : HP (ICH9) USB Universal Host Controller
                  USB Controller 5 : HP (ICH9) USB Universal Host Controller
                  USB Controller 6 : HP (ICH9) USB Universal Host Controller
                  USB Controller 7 : HP (ICH9) USB Universal Host Controller
                  USB Controller 8 : HP (ICH9) USB2 Enhanced Host Controller
                  FireWire/1394 Controller 1 : HP FW322/323 IEEE1394 OHCI FireWire Controller
                  SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
                  Printers and Faxes
                  Printer : DocuCom PDF Driver (2400x2400, Colour)
                  Printer : Amyuni Document Converter 400 (2400x2400, Colour)
                  Printer : Nuance Image Printer Driver (600x600)
                  Printer : Microsoft XPS Document Writer (600x600, Colour)
                  Fax : Microsoft Shared Fax Driver (200x200)
                  Printer : Brother FAX-4100 USB (600x600, USB)
                  Printer : Adobe PDF Converter (4000x4000, Colour)
                  Scanners and Cameras
                  Scanner : FUJITSU fi-6130dj (Scanner, USB)
                  Peripherals
                  Media Player :   ()
                  Media Player :   ()
                  Media Player :   ()
                  Media Player :   ()
                  Network Services
                  Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
                  Network Adapter : Bluetooth Device (Personal Area Network) #2
                  Wireless Adapter 1 : 802.11n Wireless PCI Express Card LAN Adapter (802.11g (ERP), WEP n-bit, 24Mbps)
                  Power Management
                  Mains (AC) Line Status : On-Line
                  Operating System
                  Windows System : Microsoft Windows 7 Ultimate 6.01.7600
                  Platform Compliance : x64
                  Windows Experience Index
                  Current System : 5.3
                  Performance Tips
                  Tip 2546 : Large memory modules should be ECC/Parity.
                  Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
                  • 6. Re: Premiere Elements 8 problems
                    Looks like a stout system, thanks.
                    Did not see the date of your nVidia video card, but might have missed it. Do you have the date handy?
                    Now, can you also tell us about the programs and Processes that launch/run at boot up? *
                    Please tell us about your Windows Virtual Memory. What is the size, and where located, plus how it's managed - statically, or dynamically?
                    What is your Project Preset?
                    What are the specs. of your source files?
                    Do you get any specific error, or warning messages.
                    * if you have more than about 30-40 Processes running, this ARTICLE might be useful for cleaning things up a bit.
                    • 7. Re: Premiere Elements 8 problems
                      nealeh Level 5
                      As your PC exceeds mine on all fronts I'm intrigued to know which component is dragging your Windows Experience down to 5.3. On mine (5.8) it is the primary disk drive. Graphics are 6.8 and Processor and RAM 7.1.
                      Cheers,
                      Neale
                      • 8. Re: Premiere Elements 8 problems
                        Halmeister Level 1
                        Component
                        Details
                        Subscore
                        Base score
                        Processor
                        2.66GHz
                        7.2
                        Memory (RAM)
                        8.00 GB
                        7.2
                        5.3
                        Graphics
                        5.3
                        Determined by
                        Gaming graphics
                        4094 MB Total available graphics memory
                        6.4
                        lowest subscore
                        Primary hard disk
                        148GB Free (279GB Total)
                        5.9
                        Windows 7 Professional
                        Looks like the lowest score sets the base score.
                        • 9. Re: Premiere Elements 8 problems
                          Halmeister Level 1
                          Video Adapter
                          Display : \\.\DISPLAY1
                          VGA Compatible : No
                          Official Device Name : NVIDIA GeForce 9500 GS
                          Hardware ID : PCI\VEN_10DE&DEV_0644&SUBSYS_13301462&REV_A1
                          OEM Device Name : nVidia G96 [GeForce 9500 GS]
                          URL : http://www.nvidia.com
                          Device Name : MSI G96 [GeForce 9500 GS]
                          Chipset
                          Model : NV96
                          Revision : A1
                          Speed : 552MHz
                          Shader Speed : 1.4GHz
                          Peak Processing Performance (PPP) : 89.6GFLOPS
                          Adjusted Peak Performance (APP) : 80.64WG
                          RAMDAC Speed : 400MHz
                          Unified Shaders : 32 Unit(s)
                          Raster Operation Units (ROP) : 8 Unit(s)
                          Texture Mapping Units (TMU) : 16 Unit(s)
                          Maximum Pixel Fillrate : 4.42GPixel/s
                          Maximum Texture Fillrate : 8.83GTexel/s
                          Logical/Chipset Memory Banks
                          Total Memory : 512MB DDR2
                          Memory Bus Speed : 2x 500MHz (1GHz)
                          Channels : 2
                          Width : 64-bit
                          Maximum Memory Bus Bandwidth : 15.63GB/s
                          Bus
                          Type : PCIe
                          Version : 1.00
                          Width : x16 / x16
                          Speed : 2.5Gbps / 2.5Gbps
                          Maximum Bus Bandwidth : 4GB/s
                          Video BIOS
                          Date of Manufacture : Friday, June 02, 2000
                          Version : 62.94.1F.00.26
                          System i2c Controller 1
                          Model : nVidia GT-GFX DDC1 i2c
                          Speed : 50kHz
                          System i2c Controller 2
                          Model : nVidia GT-GFX DDC2 i2c
                          Speed : 50kHz
                          System i2c Controller 3
                          Model : nVidia GT-GFX DDC3 i2c
                          Speed : 50kHz
                          System i2c Controller 4
                          Model : nVidia GT-GFX DDC4 i2c
                          Speed : 50kHz
                          System i2c Controller 5
                          Model : GeForce 9500 GS DDC16
                          Version : 0.A1
                          Environment Monitor 1
                          Model : nVidia GFX NV96 A1 HwMon
                          Version : 10.01
                          Temperature Sensor(s)
                          CPU Temperature : 55.00°C
                          Cooling Device(s)
                          Auto Fan Speed Control : Yes
                          CPU Fan : 750rpm
                          Direct3D 10 Devices
                          Interface Version : 10.00
                          Unified Shaders : 4.00
                          Library Version : 8.15.11.8627
                          Model : NVIDIA GeForce 9500 GS
                          Physical Memory : 512MB
                          Texture Memory : 3.5GB
                          Direct3D 9 Devices
                          Interface Version : 9.00
                          Video Driver : nvd3dumx.dll
                          Has 3D Hardware Acceleration : Yes
                          Hardware Transform & Light : Yes
                          Heads : 1
                          Pixel Shaders Version : 3.00
                          Vertex Shaders Version : 3.00
                          Accelerated Video Decoders
                          MPEG2 IDCT : Yes
                          VC1-C (VC1 IDCT) : Yes
                          WMV9-C (WMV9 IDCT) : Yes
                          H264-E (H264 VLD NoFGT) : Yes
                          Accelerated Video Processors
                          Pixel Adaptive Device : Yes
                          {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB} : Yes
                          Progressive Device : Yes
                          Bob Device : Yes
                          Software Device : Yes
                          Video Driver
                          Expected Windows Version : 4.00
                          Screen Saver Active : 5 minute(s)
                          Low Power Saving Active : No
                          Power Off Saving Active : No
                          Mode
                          Mode : 1280x800 16M+ TrueColour (32-bit)
                          Refresh Rate : 59Hz
                          Virtual Desktop Size : 1280x800
                          Supported Video Modes
                          Mode 7 : 640x480 16M+ TrueColour (32-bit) 59Hz 59Hz 60Hz 59Hz 60Hz 60Hz 72Hz 75Hz
                          Mode 22 : 720x480 16M+ TrueColour (32-bit) 59Hz 59Hz 60Hz 59Hz 60Hz 56Hz 56Hz 56Hz 72Hz 72Hz 72Hz 75Hz 75Hz 75Hz 60Hz
                          Mode 38 : 720x576 16M+ TrueColour (32-bit) 50Hz 59Hz 59Hz 59Hz 56Hz 56Hz 56Hz 60Hz 60Hz 60Hz 72Hz 72Hz 72Hz 75Hz 75Hz 75Hz
                          Mode 47 : 800x600 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 56Hz 60Hz 72Hz 75Hz
                          Mode 59 : 960x600 16M+ TrueColour (32-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz 70Hz 70Hz 70Hz 75Hz 75Hz 75Hz
                          Mode 67 : 1024x768 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 70Hz 75Hz
                          Mode 74 : 1152x864 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 75Hz
                          Mode 81 : 1280x720 16M+ TrueColour (32-bit) 50Hz 59Hz 59Hz 60Hz 59Hz 60Hz 60Hz
                          Mode 87 : 1280x768 16M+ TrueColour (32-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 93 : 1280x800 16M+ TrueColour (32-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 99 : 1280x960 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 106 : 1280x1024 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 75Hz
                          Mode 112 : 1360x768 16M+ TrueColour (32-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 113 : 1600x1200 16M+ TrueColour (32-bit) 60Hz
                          Mode 121 : 640x480 64K HiColour (16-bit) 59Hz 59Hz 60Hz 59Hz 60Hz 60Hz 72Hz 75Hz
                          Mode 136 : 720x480 64K HiColour (16-bit) 59Hz 59Hz 60Hz 59Hz 60Hz 56Hz 56Hz 56Hz 72Hz 72Hz 72Hz 75Hz 75Hz 75Hz 60Hz
                          Mode 152 : 720x576 64K HiColour (16-bit) 50Hz 59Hz 59Hz 59Hz 56Hz 56Hz 56Hz 60Hz 60Hz 60Hz 72Hz 72Hz 72Hz 75Hz 75Hz 75Hz
                          Mode 161 : 800x600 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 56Hz 60Hz 72Hz 75Hz
                          Mode 173 : 960x600 64K HiColour (16-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz 70Hz 70Hz 70Hz 75Hz 75Hz 75Hz
                          Mode 181 : 1024x768 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 70Hz 75Hz
                          Mode 188 : 1152x864 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 75Hz
                          Mode 195 : 1280x720 64K HiColour (16-bit) 50Hz 59Hz 59Hz 60Hz 59Hz 60Hz 60Hz
                          Mode 201 : 1280x768 64K HiColour (16-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 207 : 1280x800 64K HiColour (16-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 213 : 1280x960 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 220 : 1280x1024 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 75Hz
                          Mode 226 : 1360x768 64K HiColour (16-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 227 : 1600x1200 64K HiColour (16-bit) 60Hz
                          Mode 235 : 640x480 256 colours (8-bit) 59Hz 59Hz 60Hz 59Hz 60Hz 60Hz 72Hz 75Hz
                          Mode 250 : 720x480 256 colours (8-bit) 59Hz 59Hz 60Hz 59Hz 60Hz 56Hz 56Hz 56Hz 72Hz 72Hz 72Hz 75Hz 75Hz 75Hz 60Hz
                          Mode 266 : 720x576 256 colours (8-bit) 50Hz 59Hz 59Hz 59Hz 56Hz 56Hz 56Hz 60Hz 60Hz 60Hz 72Hz 72Hz 72Hz 75Hz 75Hz 75Hz
                          Mode 275 : 800x600 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 56Hz 60Hz 72Hz 75Hz
                          Mode 287 : 960x600 256 colours (8-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz 70Hz 70Hz 70Hz 75Hz 75Hz 75Hz
                          Mode 295 : 1024x768 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 70Hz 75Hz
                          Mode 302 : 1152x864 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 75Hz
                          Mode 309 : 1280x720 256 colours (8-bit) 50Hz 59Hz 59Hz 60Hz 59Hz 60Hz 60Hz
                          Mode 315 : 1280x768 256 colours (8-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 321 : 1280x800 256 colours (8-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 327 : 1280x960 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 334 : 1280x1024 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 75Hz
                          Mode 340 : 1360x768 256 colours (8-bit) 59Hz 59Hz 59Hz 60Hz 60Hz 60Hz
                          Mode 341 : 1600x1200 256 colours (8-bit) 60Hz
                          Mode 348 : 640x400 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 70Hz
                          Mode 354 : 1400x1050 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 360 : 1440x900 256 colours (8-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 362 : 1680x1050 256 colours (8-bit) 59Hz 60Hz
                          Mode 369 : 640x400 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 70Hz
                          Mode 375 : 1400x1050 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 381 : 1440x900 64K HiColour (16-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 383 : 1680x1050 64K HiColour (16-bit) 59Hz 60Hz
                          Mode 390 : 640x400 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz 70Hz
                          Mode 396 : 1400x1050 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 402 : 1440x900 16M+ TrueColour (32-bit) 59Hz 60Hz 59Hz 60Hz 59Hz 60Hz
                          Mode 404 : 1680x1050 16M+ TrueColour (32-bit) 59Hz 60Hz
                          Mode 406 : 1440x480 256 colours (8-bit) 29Hz 30Hz
                          Mode 407 : 1440x576 256 colours (8-bit) 25Hz
                          Mode 409 : 1440x480 64K HiColour (16-bit) 29Hz 30Hz
                          Mode 410 : 1440x576 64K HiColour (16-bit) 25Hz
                          Mode 412 : 1440x480 16M+ TrueColour (32-bit) 29Hz 30Hz
                          Mode 413 : 1440x576 16M+ TrueColour (32-bit) 25Hz
                          Device Mode Characteristics
                          Physical Medium Width : 452 mm, 18 in
                          Physical Medium Height : 282 mm, 11 in
                          Recommended Display Size : 25 in
                          Horizontal/Vertical Resolution : 96x96 dpi
                          Colour Bits/Planes : 32-bit / 1-bit
                          Brushes : 4294967295
                          Pens : 4294967295
                          Colours/Shades : 4294967295
                          Pixel Width/Height/Diagonal : 36 / 36 / 51
                          Clipping Capabilities
                          Can Clip Output to Rectangle : Yes
                          Can Clip Output to Region : No
                          Raster Capabilities
                          Supports Banding : No
                          Supports Fonts Larger than 64Kb : Yes
                          Can Transfer Bitmaps : Yes
                          Supports Bitmaps Larger than 64Kb : Yes
                          Supports Device Bitmaps : No
                          Supports DIBs : Yes
                          DIBs on Device Surface : Yes
                          Flood Fills : Yes
                          Supports Windows 2.x : Yes
                          Stretch/Compress Bitmaps : Yes
                          Stretch/Compress DIBs : Yes
                          Supports Scaling : No
                          Palette-Based Device : No
                          Saves Bitmap Locally : No
                          Curve Capabilities
                          Can Draw Circles : Yes
                          Can Draw Ellipses : Yes
                          Can Draw Pie Wedges : Yes
                          Can Draw Chord Arcs : Yes
                          Can Draw Wide Borders : Yes
                          Can Draw Styled Borders : Yes
                          Can Draw Wide, Styled Borders : Yes
                          Can Draw Rounded Rectangles : Yes
                          Can Draw Interiors : Yes
                          Line Capabilities
                          Can Draw Polylines : Yes
                          Can Draw Styled Lines : Yes
                          Can Draw Wide Lines : Yes
                          Can Draw Wide, Styled Lines : Yes
                          Can Draw Markers : Yes
                          Can Draw Polymarkers : Yes
                          Polygonal Capabilities
                          Can Draw Alternate-fill Polygons : Yes
                          Can Draw Winding-fill Polygons : Yes
                          Can Draw Rectangles : Yes
                          Can Draw Scan Lines : Yes
                          Text Capabilities
                          Supports Stroke Clip Precision : Yes
                          Supports Stroke Output Precision : Yes
                          Supports Character Output Precision : Yes
                          Supports 90° Character Rotation : No
                          Supports Any Angle Character Rotation : No
                          Supports Independent X-Y Scaling : No
                          Supports Doubled Character for Scaling : No
                          Supports Integer Multiples for Scaling : No
                          Any Multiples for Exact Scaling : No
                          Can Draw Double-Weighted Characters : No
                          Can Italicise : No
                          Can Underline : Yes
                          Can Draw Strikeouts : Yes
                          Can Draw Raster Fonts : Yes
                          Can Draw Vector Fonts : Yes
                          Cannot Scroll Using BitBlt : No
                          Enhanced Video Settings
                          Animation Effects Enabled : No
                          Full Windows Drag Enabled : No
                          Font Smoothing Enabled : No
                          HighContrast Feature On : No
                          SiSoftware Sandra
                          System Memory Summary
                          Total Physical Memory : 8GB
                          Free Physical Memory : 4.2GB, 52%
                          Maximum Page File : 16GB
                          Free Page File : 12.75GB, 80%
                          Page File : ?:\pagefile.sys
                          Kernel Statistics
                          Total Processes : 119
                          Total Threads : 1426
                          Total Open Handles : 36538
                          Kernel Memory Information
                          Total Memory : 559.26MB
                          Paged Memory : 424.6MB
                          Non-Paged Memory : 134.66MB
                          Page Commit Charge Statistics
                          Total Committed : 852368
                          Peak Commits : 1320752
                          Maximum Commits : 4193434
                          Extended Memory Information
                          Allocated Memory Load : 47%
                          • 10. Re: Premiere Elements 8 problems
                            Halmeister Level 1
                            Here is a CamStudio vid of what I see on my computer when I run Adobe Premiere 8.
                            This is all it will do. The project is empty. It will crash no mater what I do. Start a new project, or open a project I tried to start that crashed. I have never been able to add any vid. It has always crashed before I can do anything.
                            https://www.photoshop.com/user/publicgalleryforme
                            • 11. Re: Premiere Elements 8 problems
                              Halmeister Level 1
                              See date above. Looks like HP installed a card manufactured about 9 years before I bought the computer.
                              Is there a problem with the specs?
                              Usual stuff. I use the new free Microsoft Antivirus, gotomypc, sync, I disabled Carbonite and Google search and World Community Grid.
                              See above. How SHOULD it be set to run this program successfully?
                              What is that? If it is set during operation of the program I am not able to deal with it because the program crashes before I even move my mouse.
                              Never got that far.
                              Watch the vid. Same thing every time.
                              Thank you. I usually don't expect to rely on luck when I install an Adobe product.
                              • 12. Re: Premiere Elements 8 problems
                                Halmeister Level 1
                                I have seen some posts about nvidia cards not working with P8.
                                I have an nvidia card.
                                How would I check to see if that is the ploblem?
                                (without actually switching cards)
                                • 13. Re: Premiere Elements 8 problems
                                  Here is the current nVidia driver: 197.13, dated: 03/25/2010.
                                  With all that data, I still have not seen the driver #, or date. Probably the easiest way to get that is to go to Start>Run and type "dxdiag.exe," without the " marks. Look at the Display tab, and then the Drivers pane. Your nVidia driver will be listed there.
                                  If it is not the one above, then go to the nVidia site, download that driver (or later one, if you go tomorrow, or the next day, as these change rapidly) and read the installation instructions. Note: different cards and different drivers require different installation actions. Most are just a simple run the executable, but some can get rather involved. Read the instructions for your card, and for the downloaded driver, and follow those to the letter.
                                  • 14. Re: Premiere Elements 8 problems
                                    If you hit Ctrl+Alt+Del, you will get Task Manager. Go to the Processes tab, and just do screen-caps of that list. Note, if you do not have a screen-cap program, like Snag-it, you will need to do several, as that list is scrollable, and you'll want the full list, i.e. several screen-caps to show all of the processes.
                                    Likely that you have many extra programs and Processes running, that you do not need. This ARTICLE will tell you how to set up your computer and get it ready for an editing session.
                                    The easiest way to get this info is to go to Control Panel>System>Advanced>Performance>Settings>Advanced>Virtual Memory>Change. That will bring up the Virtual Memory screen, where you can see, and set, the Virtual Memory. Again, a screen-cap will tell us all about it.
                                    When one begins a New Project, they will choose a Project Preset from a drop-down menu. That is what we need to know - what was chosen?
                                    • 15. Re: Premiere Elements 8 problems
                                      Did you fill in the info requested in that pop-up message?
                                      Did you give Adobe your e-mail address to allow them to furnish you with details of your crash?
                                      • 16. Re: Premiere Elements 8 problems
                                        When a program, or system crashes, or hangs, there is often a "breadcrumb trail" left behind. This ARTICLE will give you tips on finding clues as to what was happening just before and during the crash. For this, Event Viewer will be your friend. Check any and all error, or warning messages. Many will just be code, and will be useless. It is very likely that some will have links. Follow each and every link furnished. Some will lead to the MS site, and some might lead to a vendor's site. Be patient, and look at EVERY error, or warning message, around the time of the crash. It is probably easiest to just launch PrE 8, let it crash and just note the time. That will narrow things down a bit, but look before the crash too. Check the Applications and the System tabs for the error, or warning messages.
                                        • 17. Re: Premiere Elements 8 problems
                                          You might want to take a look at this ARTICLE from the PrPro forum, regarding cleaning up one's system.
                                          • 18. Re: Premiere Elements 8 problems
                                            You might want to also look into MS's SystemEssentials.
                                            • 19. Re: Premiere Elements 8 problems
                                              26.2morgan Level 1
                                              Thanks for all the info I'll have digest it all. I've  been busy and have been on much latley but just recorded a lacrosse game yesterday in HD and decided to load the Image Mixer 3 video editing software that came with the camera. Although it is basic editing, it worked, and I was actually able to edit clips which I can't with adobe because the preview is so choppy ect. I really want to use the software that I spent 149.00 dollars for, and cant believe free software works better.
                                              • 20. Re: Premiere Elements 8 problems
                                                Halmeister Level 1
                                                Thanks so much for the personalized attention on this!
                                                I am working through some of these issues tonight.
                                                My driver did need updating and I am doing that now.
                                                We'll see how it goes.
                                                • 21. Re: Premiere Elements 8 problems
                                                  Let's hope that if this does not "cure" things, they at least improve.
                                                  Keep us posted,
