3 Replies Latest reply on Apr 5, 2010 1:35 PM by levancho
    port flex app from tomcat to oracle oas
    msdawgs
      any direction given will be appreciated. i have a flex 3 app up and running on my localhost. i'm using a local install of tomcat(6.0.18) and i'm also using blazeds(3.2.0.3978). this combined java/flex app is using remote objects connecting to a back end oracle db on a diff host. as i mentioned... this app runs fine on my local tomcat server. i'm looking for docs or direction to port this over to an oracle app server(10.1.3.4). i have exported my project as a war file... deployed it error free on my OAS 10.1..3.4 server. the app loads but fails to do any remoting with [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 404: url: 'http:/*****/messagebroker/amf'"]. i'm not sure if there are config changes i need to make before export or after deployment on oracle app server.
      thanks
      -doug-
        • 1. Re: port flex app from tomcat to oracle oas
          levancho Level 3
          there is nothing special step about deploying it on diffrent app servers,
          I would first check url: http:/*****/messagebroker/amf in browser, and see what display you will get,if its blank, than servlet is running, if not , check startup log to make sure that your application got deployed without errors, and lastly check flex-config file and make sure you are not  ussing tomcatLoginCommand if you are ussing security features of blazeDS, tomcatLoginCommand most likely will not work with oracle App server, I am not sure what web container engine oracle app server is ussing but I doubt its tomcat anyways.
          • 2. Re: port flex app from tomcat to oracle oas
            msdawgs Level 1
            thanks for the reply...
            url returns...Servlet error: An exception occurred. The current application deployment descriptors do not allow for including it in this response. Please consult the application log for details.
            let me take a step back... i have not done any initial config of this oracle app server for this particular application. do i need to get blazeds.war and ojdbc14.jar over there first? then deploy?
            thanks
            -doug-
            • 3. Re: port flex app from tomcat to oracle oas
              levancho Level 3
              All jars are inside war so no need to conf, look inside oracle all server logs for error
              -- Sent from my Palm Pre
              url returns...404 Not FoundServlet error: An exception occurred. The current application deployment descriptors do not allow for including it in this response. Please consult the application log for details.
              let me take a step back... i have not done any initial config of this oracle app server for this particular application. do i need to get blazeds.jar and ojdbc14.jar over there first? then deploy?
              thanks
              -doug-
