4 Replies Latest reply on Apr 7, 2010 7:56 AM by GeorgeWS
    Combobox to combobox
    GeorgeWS Level 1
      I have a combobox filled by an arraycollection from a RO. I have a second Combobox filled from a similar arraycollection. How can I get the first combo to filter the 2nd. I can filter a grid no problem but when it comes down to the filterFunction I do not know what to make my filters equal to.
      public function accFilterFunction(item:Object):Boolean {
      if (accfilter.selectedItem.label == ? ){
      return true;
      } else{
      return false
      Im not sure about the item part of the first line maybe this only applies to datagrids? Also where the ? is I dont know what id be setting the accfilter (my first combobox id) to. Any thoughts, code help
      George
        • 1. Re: Combobox to combobox
          SpaghettiCoder Level 3
          private function filter():void
               arrayCollection.filterFunction = applyFilter;
               arrayCollection.refresh();
          private function applyFilter(item:Object):Boolean
               if ( )
                    return true;
               else
                    return item.columnName == someVariable;
          • 2. Re: Combobox to combobox
            GeorgeWS Level 1
            No...
            This is very close im sure:
            public function aacFilterFunc(item::Object):Boolean {
                 if (accfilter.selectedItem.label == myDisplay.getItemAt()) {
            return true;
            { else {
            return false;
            I dont know what this should be? myDisplay.getItemAt()
            if I make it myDisplay.getItemAt(0) and I pick "Ralphs" from accfilter combobox it works. Ralphs happens to be in the first row of my data.
            accfilter is the id of my first ComboBox
            How do I get the list of the data items in the MyDisplay arrayCollection?
            I would think something easy like: myDisplay.getItemAt(data); but I can tell thats to easy sheesh there are only 2 fields, data and label
            Flex sucks when it comes to combobox
            • 3. Re: Combobox to combobox
              You have two combo boxes right?
              combobox 1, combobox2,
              when you select something in combobox1 it filters the available contents of combobox2???
              is that what you're trying to do?
              • 4. Re: Combobox to combobox
                GeorgeWS Level 1
                Got it, wow and it was easier than I thought
                     if (accfilter.selectedItem.label == item.data) {
                return true;
                { else {
                return false;
