2 Replies Latest reply on Apr 11, 2010 2:10 PM by BKBK
    cffile upload and type="file"  ... how do I get form value ...
    cf_code_warrior Level 1
      <input class="pfs" type="File" name="file_name" size="120" maxlength="100">
      I send this to a cffile type="upload" ... and I am trying to do a special error handler ...
      If file exists on server, first move it to an archive folder, then upload new one to destination folder.
      BUT the form name of file_name - nowhere does it contain the file name, instead ...
      C:\CFusionMX7\runtime\servers\coldfusion\SERVER-INF\temp\wwwroot-tmp\neotmp41631.tmp
      Hummmm.  Never tried this b4 ... how DO I get the file name!?
        • 1. Re: cffile upload and type="file"  ... how do I get form value ...
          ilssac
          Yes that is where the web server put the file and told ColdFusion so ColdFusion can do what it wants with it.
          The documentation has some good information that would probably help you.
          But you may want to explore the <cfdump var=#cffile#> structure.
          Also, the <cffile ...> tag is properties that can help with name collisions.
          To do what you want my require a try/catch or temporaray name, move and rename approach.
          • 2. Re: cffile upload and type="file"  ... how do I get form value ...
            BKBK Adobe Community Professional & MVP
            Here is a fully worked out example. It requires you to first create the directories c:\archive and c:\uploads.
            I am on Coldfusion 8. In the case where an error is thrown, Coldfusion stores the name of the existing file as cfcatch.dest. I wonder whether that will be the same in MX7.
            When there is no name conflict, the file is uploaded to c:\uploads.
            The code within cfcatch doesn't run.
            When there is a name conflict, Coldfusion throws an error.
            The code within cfcatch runs.
            The existing file is moved to c:\archive.
            The current file is uploaded to c:\uploads
            <cfif isDefined("Form.FileContents") >
                <cftry>
                    <cffile action = "upload"
                        fileField = "FileContents"
                        destination = "c:\uploads"
                        nameConflict = "error">
                        File successfully uploaded.
                <cfcatch type="application">
                    <!--- Full path to existing file of same name as uploaded file --->
                     <cfset fullPathOfExistingFile = cfcatch.dest>
                    <!--- Move existing file to archive --->
                    <cffile
                        action = "move"
                        source = "#fullPathOfExistingFile#"
                        destination = "c:\archive">
                    File successfully moved.<br>
                   <!--- upload file --->
                         nameConflict = "overwrite">
                </cfcatch>
                </cftry>
            <cfelse>
                <form method="post" action="<cfoutput>#cgi.SCRIPT_NAME#</cfoutput>" enctype="multipart/form-data">
                    <input name="FileContents" type="file">
                    <br>
                    <input name="submit" type="submit" value="Upload File">
                </form>
            </cfif>
