10 Replies Latest reply on Apr 15, 2010 10:15 AM by PankajN
    AEE Rendering incorrectly
    c.joe
      Hey everyone.
      Two problems here.
      For some reason, my After Effects is not rendering exactly what is previewed on the composition.
      Here are pictures to explain what I'm talking about.
      This is what you see when you render it out and play it through Windows Media Player:
      http://img31.imageshack.us/img31/6961/36815478.png
      Here's what it's suppose to look like on my composition. (Or at least what I previewed)
      http://img682.imageshack.us/img682/1941/54398216.png
      My whole project is pretty big. I'm doing a credits roll and its about 45 seconds long & (2200 x 1357).
      Also another problem that I ran into was the "unable to allocate space for 2200 x 1357 image buffer" & "you may be experiencing fragmentation" etc.
      I was able to render the first 11 seconds of the clip before it messed up; that's how I saw that it rendered incorrectly. I could also see that it was rendering incorrectly when I was watching the preview composition going frame by frame as it as it was rendering and noticing that it was very off. I believe I have found a few solutions for the "unable to allocate space" etc but I haven't bothered trying since my composition isn't even rendering correctly.
      Two problems here.
      Thanks in advance.
      -Chris
        • 1. Re: AEE Rendering incorrectly
          The first question is why this comp size? It's not a standard that I recognize.
          The second, what are your render settings, ram, preferences...
          Maybe then we can point you in the right direction.
          • 2. Re: AEE Rendering incorrectly
            c.joe Level 1
            Thanks for the quick reply
            I'm not sure. The comp size sort of set itself when I dragged in a few files to create the room. It looked correct so I stuck with it.
            I have 4gb ram, 3.5 usable. But "Total After Effects memory usage" is 1.2 gb. "RAM to leave for other applications" 0.25 gb
            Multiproccessing is OFF
            I enabled Disk Cache with a max size of 2000 MB.
            Onto render settings...
            Quality - Best
            Resolution - Full
            Size is set at 2200x1357
            Disk Cache - Read Only
            OpenGL renderer is unchecked
            No proxies used,
            Effects - current settings
            Solo switches - current settings
            Guide layers - ALL OFF
            Color Depth - 16 bits per channel
            Frame blending - On for checked layers
            Field Render - Lower field first
            3:2 pulldown WSSWW   comp's frame rate 23.976 but using framerate 29.970
            Motion Blur - On for checked layers only
            Time Span - Work Area Only
            Use storage overflow is checked.
            Output Module Settings:
            Format - Video for Windows
            Post Render Action - None
            Include project link & Include Source XMP Metadata is both checked
            Channels: RGB
            Depth: Millions of Colors
            Color: Premutiplied (matted)
            No format options / compression.
            Thanks again for the quick reply.
            • 3. Re: AEE Rendering incorrectly
              Todd_Kopriva Level 8
              When you render for final output, the movie is rendered through the view of the active camera. Are you previewing through the active camera view and comparing that to your final movie? If you post a screenshot of the entire Composition panel, then it will be easier for us to see things like this for troubleshooting.
              • 4. Re: AEE Rendering incorrectly
                c.joe Level 1
                Hi Todd, Thanks for the reply.
                Yes I am previewing through the Active Camera.
                Here's a screenshot of the entire Panel. Sorry it is a bit big because I am on a widescreen monitor.
                Click here for direct link -
                http://img693.imageshack.us/img693/3606/43079697.png
                Thanks~
                -Chris
                • 5. Re: AEE Rendering incorrectly
                  Mmh, it's definitely using a different camera view than in the preview, but why it's doing that is unclear. I would suspect, though, that your memory error relates to it. Sounds to me, like it is unable to expand the buffer in order to apply the DOF and then renders incorrectly. Can you render with DOF turned off?
                  Mylenium
                  • 6. Re: AEE Rendering incorrectly
                    c.joe Level 1
                    Thanks for the reply,
                    I rendered with DOF off but I didn't let it finish because the preview screen already showed it did not work. But I still yet to try rendering completely just to see if it can even render out 100%. I just want to make sure it works completely before I attempt to take an hour to render it out.
                    But here's how it looks on the preview screen as it renders.
                    http://img40.imageshack.us/img40/491/53939172.png
                    Still doesn't work :/
                    I appreciate the help.
                    -Chris
                    • 7. Re: AEE Rendering incorrectly
                      PankajN Adobe Employee
                      It is hard to say what might be going wrong. Can you email me your project with no media files at pankajn AT adobe.com? Please also send me the steps to reproduce the bug and I will try to repro the bug here.
                      -Pankaj
                      • 8. Re: AEE Rendering incorrectly
                        c.joe Level 1
                        Pankajn,
                        I really appreciate it. I'm sending the file now.
                        -Chris
                        • 9. Re: AEE Rendering incorrectly
                          c.joe Level 1
                          Hi, I would just like to let everyone know that the problem has been solved. Apparently, my Z value on my  on my Camera Position and POI was just too high. The "width parameter of motion tile is very high and it overflows the 32K rectangle bound in CS4"
                          Pankaj also fonud that "if the z value of camera’s position and pointOfInterest is < 37000, the problem goes away."
                          Thanks so much Pankaj for take your time to help me. I really truly appreciate it.
                          -Chris
                          • 10. Re: AEE Rendering incorrectly
                            The same project works fine in CS5 without making any camera parameter changes because there is no bound overflow.
                            Another reason to move to CS5
