2 Replies Latest reply on Apr 6, 2010 6:40 AM by kglad
    setVolume problem
    Pooya Source
      I tried to control a background music volume using this code
      soundInstance = new Sound();
      here attachSound("1");
      "1" is a linkage identifier. everything works perfect...music plays and volume decreases.
      but not only the attached sound... the whole movie volume changes even the swf I've loaded in my clip. I just need to control the background music("1" linkage) not all the sounds. what's the problem here? how can I make this happen?
      thank you
        • 1. Re: setVolume problem
          each sound is associated with a movieclip.  unless you explicitly use the movieclip in your sound constructor, the current timeline is used and your sound instance will control all sounds on the current timeline.
          to remedy, create a movieclilp to associate with each sound:
          soundInstance=new Sound(soundInstanceMC);
          • 2. Re: setVolume problem
            d0brin Level 1
            a simplier solution to this is to create a movie clip with sound control system for the BG music and that way it will not affect the rest of the sounds in your .swf
