2 Replies Latest reply on Apr 6, 2010 7:22 PM by Harry Kunz
    Document Class
    Harry Kunz Level 4
      I'm new to flex. I've explored it for a day. Since the main document is XML, i was wondering how i can create a centralized code base, like a document class to start my code execution. Instead of placing my code into an <fx script tag. Any best practices i should use? I'm using a Trial version of Flash Builder 4.
        • 1. Re: Document Class
          GordonSmith Level 4
          MXML files are just another way to write ActionScript classes. For example, if you write MyApp.mxml as
          <s:Applicaton>
              <fx:Script>
                  public var foo:int = 3;
                  public function doSomething():void
                      trace(foo);
              </fx:Script>
          </s:Application>
          then this corresponds to the ActionScript class
          public class MyApp extends spark.controls.Application
                  trace(foo);
          However, writing the app as an MXML file makes the compiler autogenerate some extra code, such as for initializing CSS styles, that is necessary for the app to run correctly.
          Gordon Smith
          Adobe Flex SDK Team
          • 2. Re: Document Class
            Harry Kunz Level 4
            Thank you for your response! i see, i see. So this first MXML file generated upon project creation, is it considered the document class? Can i instantiate an instance of another class inside the <fx:script> tag and pass a "this" to the constructor? What is the type of "this" inside that class? How can i create a script that automatically runs as the init script? I'm trying to implement the MVC framework in flex.
