2 Replies Latest reply on Apr 20, 2010 11:22 PM by rezashah95
    null check behaviour
      I have problem when doing null checking against datagrid.provider, also tried using httpservice.lastresult too.
      if(datagrid.provider == null)
           Alert.show("Null data");
      Above codes will display alert window on linux, but not on windows, and the rest of the codes below not executed.
      No visual cue at all.
      My development environment:
      - Linux 2.6.33
      - Adobe air runtime 1.5.3
      - Flex 4.0 release version
      Windows environment:
      - windows 7
      - Air runtime 1.5.3
      Anybody has clue?
        • 1. Re: null check behaviour
          joan_lafferty Adobe Employee
          Are you actually trying to check the 'dataProvider' property, rather than 'provider' on a DataGrid?
          • 2. Re: null check behaviour
            rezashah95 Level 1
            Thanks for the answer.
            The problem was different behaviour between windows and linux.
            I'm using httpservice to get data from server, but i listened only to ResultEvent.
            In linux i donot have problem when comparing dataProvider against null.
            In windows my program silently stop working without crash or any additional visual clue.
            After i added FaultEvent handler, everything works properly.
            I donot know why in linux if server return error it goes to ResultEvent, but in window it goes to FaultEvent.
