0 Replies Latest reply on Apr 6, 2010 3:23 AM by jjpower246
    Help with Spray vertical menu errors in IE
    jjpower246
      Hi, nice to meet you all.
      I have some problems with  the look of the Spry drop down vertical menu I'm making for my webpage,  it does not look correctly on IE, on others like Firefox it looks fine.
      I have added some screenshots to show you what it looks like, coz I  haven't upload the site, here it shows on IE and FF:
      You can see what the problem is, the last one on firefox is aligned  both the menu and sub-menu, that's what I want to show on IE.
      Hope someone can help me out.
      Thanks in advance, have a nice day.
      Here is a copy-paste from my SpryMenuBarVertical.css :
      @charset "UTF-8";
      /* SpryMenuBarVertical.css - Revision: Spry Preview Release 1.4 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights  reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, a fixed width box with  no margin or padding */
      ul.MenuBarVertical
      margin: 0;
      padding: 0;
      list-style-type: none;
      font-size: 10px;
      cursor: default;
      width: auto;
      list-style-image: none;
      font-family: Arial, Helvetica, sans-serif;
      font-weight: bold;
      /* Set the active Menu Bar with this class, currently setting  z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
      z-index: 1000;
      /* Menu item containers, position children relative to this  container and are same fixed width as parent */
      ul.MenuBarVertical li
      margin: 0;
      padding: 0;
      font-size: 10px;
      position: relative;
      text-align: left;
      cursor: default;
      width: auto;
      /* Submenus should appear slightly overlapping to the right (95%)  and up (-5%) with a higher z-index, but they are initially off the left  side of the screen (-1000em) */
      ul.MenuBarVertical ul
      margin: -5% 0 0 95%;
      padding: 0;
      font-size: 100%;
      position: absolute;
      z-index: 1020;
      cursor: default;
      width: 19.3em;
      left: -1000em;
      top: 12px;
      /* Submenu that is showing with class designation  MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarVertical ul.MenuBarSubmenuVisible
      left: 11px;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarVertical ul li
      width: auto;
      display: inline;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Outermost menu container has borders on all sides */
      ul.MenuBarVertical
      border: 1px solid #CCC;
      /* Submenu containers have borders on all sides */
      /* Menu items are a light gray block with padding and no text  decoration */
      ul.MenuBarVertical a
      display: block;
      cursor: pointer;
      background-color: #EEE;
      padding: 0.5em 0.75em;
      color: #333;
      text-decoration: none;
      /* Menu items that have mouse over or focus have a blue background  and white text */
      ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
      background-color: #33C;
      color: #FFF;
      /* Menu items that are open with submenus are set to  MenuBarItemHover with a blue background and white text */
      ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical  a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
      color: #FFF;
      SUBMENU INDICATION: styles if there is a submenu under a given menu  item
      /* Menu items that have a submenu have the class designation  MenuBarItemSubmenu and are set to use a background image positioned on  the far left (95%) and centered vertically (50%) */
      background-image: url(SpryMenuBarRight.gif);
      background-repeat: no-repeat;
      background-position: 95% 50%;
      /* Menu items that are open with submenus have the class designation  MenuBarItemSubmenuHover and are set to use a "hover" background image  positioned on the far left (95%) and centered vertically (50%) */
      background-image: url(SpryMenuBarRightHover.gif);
      BROWSER HACKS: the hacks below should not be changed unless you are  an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls,  we underlay each submenu with an iframe */
      ul.MenuBarVertical iframe
      position: absolute;
      z-index: 1010;
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in  float is to keep IE 5.0 from parsing */
      @media screen, projection
      ul.MenuBarVertical li.MenuBarItemIE
      background: #FFF;
      float: inherit;
