5 Replies Latest reply on Apr 6, 2010 7:03 AM by Harbs.
    Convert Graphic Frame to Text Frame
    HPS Rich
      I've a document with some basic frames in them. I need to convert them into text frames.
      I've tried PageItem.contentType = ContentType.TEXT_TYPE and while it changes the content type the page item still does not have insertionPoints.
      If I close the document directly after changing the content type then re open, the insertionPoints are accessable.
      What else do i need to do when converting the frame type?
      many thanks
      Richard
        • 1. Re: Convert Graphic Frame to Text Frame
          Shonkyin Level 3
          Hi Richard,
          Try this
          app.activeDocument.allPageItems[0].contentType = ContentType.TEXT_TYPE
          app.select(app.activeDocument.allPageItems[0].insertionPoints[0])
          Regards,
          Shonky
          • 2. Re: Convert Graphic Frame to Text Frame
            You are correct -- there seems to be a minor lag between assigning the Content type and ID actually recognizing it as such.
            I tried a few random things that did not work -- forcing "recompose" and such -- until (finally!) trying this: an explicit Select of the new object does force ID to re-evaluate the type.
            r = app.activeDocument.rectangles.add();
            try {
             x = app.selection[0].insertionPoints.length;
             alert ("Found "+x+" insertion points");
            } catch (_)
             alert ("No insertion points here");
            r.contentType = ContentType.TEXT_TYPE;
            r.select();
            try {
            } catch (_)
            • 3. Re: Convert Graphic Frame to Text Frame
              Harbs. Level 6
              The problem is caused by the peculiarities of InDesign's loose typing.
              You need to reevaluate the type like so:
              myPageItem.contentType = ContentType.TEXT_TYPE;
              myPageItem = myPageItem.getElements()[0];
              • 4. Re: Convert Graphic Frame to Text Frame
                HPS Rich Level 1
                thank you all for being so helpful,
                yep in the end I set the pageitem variable to the pageitem in the document again and it fixed the problem, presume this is a Javascript bug and not Indesign itself?  I guess Indesign is doing some other process behind the scenes when you change the content type and Javascript doesn't realise the object has changed. lol
                thanks again.
                Richard
                • 5. Re: Convert Graphic Frame to Text Frame
                  Harbs. Level 6
                  I don't think it's really a bug.
                  InDesign keeps interactions between the scripting layer and the C++ layer to a minimum to ensure maximum performance.
                  You really don't want InDesign to reevaluate the object's type  each time you change a property...
                  You are changing the object's class "behind the scripting engine's back", so the scripting layer is not aware of new properties.
                  Harbs
