12 Replies Latest reply on Sep 8, 2007 5:29 AM by Newsgroup_User
    Removing Photo Background
    Level 7
      I need some assistance! I arranged a photoshoot for a friend/client and even
      purchased a small light tent kit to do the product photography for her.
      Having never done this before, I assumed that I'd be able to use the Magic
      Wand to remove the background easily because it would be a solid color.
      The reality is that because there isn't much contrast between parts of the
      products, I'm having a heck of a time with that tool. I've tried some of the
      techniques from Linda's books, and again, because there's not much contrast,
      I haven't had much luck. There's a LOT of pictures, and I dread the thought
      of the hours I'd have to spend with the pen tool to do a decent job with
      this.
      I posted a sample here: http://www.eranaturalbeauty.com/testing/, and would
      appreciate any ideas on how I can remove that background - the client wants
      a plain white behind the products. Thanks!
      ~ Bruce
      Quit laughing at me if you want to send me email!
        • 1. Re: Removing Photo Background
          Level 7
          On Fri, 07 Sep 2007 17:53:09 +0400, MrBruce <mrbrucecHA@HAhotHAmail.com>
          > even purchased a small light tent kit to do the product photography for
          > her. Having never done this before, I assumed that I'd be able to use
          > the Magic Wand to remove the background easily because it would be a
          > solid color.
          > the products, I'm having a heck of a time with that tool. I've tried
          > some of the techniques from Linda's books, and again, because there's
          > not much contrast, I haven't had much luck. There's a LOT of pictures,
          > and I dread the thought of the hours I'd have to spend with the pen tool
          > to do a decent job with this.
          > would appreciate any ideas on how I can remove that background - the
          > client wants a plain white behind the products. Thanks!
          For that cylindrical packs, using vector masks should be pretty easy and,
          most likely, provide the best solution.
          For things like leaves and fruits, Windows users may use this:
          http://research.graphicon.ru/image-processing/gml-matting-6.html
          work reasonably well. Not so perfect with packs due to low local contrast,
          but if you don't need to remove table, looks good enough to me.
          Ilya Razmanov
          http://photoshop.msk.ru - Photoshop plug-in filters
          • 2. Re: Removing Photo Background
            Level 7
            "Ilya Razmanov" <ilyich@ioc.ac.ru> wrote in message
            news:op.tyaesqhw6e3g07@l2.ioc.ac.ru...
            >> solid color.
            > Ilya Razmanov
            Thank you, Ilya! I will experiment with that!
            ~ Bruce
            • 3. Re: Removing Photo Background
              Level 7
              >>> and even purchased a small light tent kit to do the product
              >>> photography for her. Having never done this before, I assumed that
              >>> I'd be able to use the Magic Wand to remove the background easily
              >>> of the products, I'm having a heck of a time with that tool. I've
              >>> tried some of the techniques from Linda's books, and again, because
              >>> there's not much contrast, I haven't had much luck. There's a LOT of
              >>> pictures, and I dread the thought of the hours I'd have to spend with
              >>> the pen tool to do a decent job with this.
              >> and, most likely, provide the best solution.
              >> contrast, but if you don't need to remove table, looks good enough to me.
              >> Ilya Razmanov
              > ~ Bruce
              A bit late for this advice now, Bruce, but traditionally, if objects
              need to be close cut, the photographer would shoot them individually and
              use cards (black, white or gray) to help separate the object from the
              background. These "separators" would need to be positioned so they do
              not reflect in the product surface. This makes it quite easy to close
              cut the images with the magic wand or other matting tools. If a group
              arrangement is necessary, make sure that your background color choice
              does not appear in the products (white lids, white background) and also
              that the color is a neutral one, if the products are sitting on the
              backdrop.
              I was able to get some decent result in about 10 minutes by doing the
              following:
              1 -open the image and create two duplicates.
              2- On the top duplicate, apply Color Burn blend mode
              3 - Select the blend object and the one directly beneath it and flatten
              those two objects only. This will leave you with two objects, one much
              darker and the other normal.
              4- set your magic wad to about 22 tolerance ad start shift clicking to
              select the background. You may have to alter the tolerance occasionally.
              5 -With the background selected, go to Select > Inverse
              6 -Optionally, you can smooth the selection but no more than 1 pixel or two.
              7 - Select > Save the bitmap selection. This way you can reload it if
              necessary.
              8 -Select > Convert to Marquee to Path
              9 - hide and lock the dark image so only the original shows up.
              10- cut the new path
              11 - Edit > Paste as mask
              12- Because it's a vector mask, you can use the sub selection tool to
              further tweak the mask.
              Hope this helps.
              Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
              Extending Knowledge, Daily
              http://www.communityMX.com/
              CommunityMX - Free Resources:
              http://www.communitymx.com/free.cfm
              .:Adobe Community Expert for Fireworks:.
              news://forums.macromedia.com/macromedia.fireworks
              news://forums.macromedia.com/macromedia.dreamweaver
              • 4. Re: Removing Photo Background
                Level 7
                "Jim Babbage .:CMX:. & .:Adobe Community Expert:."
                <jbabbage@newmediaservices.ca> wrote in message
                news:fbrrti$q5l$1@forums.macromedia.com...
                >>>> solid color.
                >>> me.
                >>> Ilya Razmanov
                >> ~ Bruce
                > A bit late for this advice now, Bruce, but traditionally, if objects need
                > to be close cut, the photographer would shoot them individually and use
                > background. These "separators" would need to be positioned so they do not
                > reflect in the product surface. This makes it quite easy to close cut the
                > images with the magic wand or other matting tools. If a group arrangement
                > is necessary, make sure that your background color choice does not appear
                > in the products (white lids, white background) and also that the color is
                > a neutral one, if the products are sitting on the backdrop.
                > following:
                > two.
                > necessary.
                > Hope this helps.
                Thanks, Jim! I guess I won't be making THAT mistake again!
                I'll be trying your solution shortly - will let you know how I make out!
                ~ Bruce
                • 5. Re: Removing Photo Background
                  Level 7
                  "MrBruce" <mrbrucecHA@HAhotHAmail.com> wrote in message
                  news:fbrsls$qu0$1@forums.macromedia.com...
                  >>>>> photography for her. Having never done this before, I assumed that I'd
                  >>>>> be able to use the Magic Wand to remove the background easily because
                  >>>> me.
                  >>>> Ilya Razmanov
                  >>> ~ Bruce
                  >> following:
                  >> two.
                  >> necessary.
                  >> Hope this helps.
                  > ~ Bruce
                  Jim...
                  I just went to try this and got caught at Step 2! I have Fireworks 8 and I
                  can't find a "Color Burn blend mode."
                  ~ Bruce
                  • 6. Re: Removing Photo Background
                    Level 7
                    >>>>>> friend/client and even purchased a small light tent kit to do the
                    >>>>>> product photography for her. Having never done this before, I
                    >>>>>> assumed that I'd be able to use the Magic Wand to remove the
                    >>>>>> parts of the products, I'm having a heck of a time with that tool.
                    >>>>>> I've tried some of the techniques from Linda's books, and again,
                    >>>>>> because there's not much contrast, I haven't had much luck.
                    >>>>>> There's a LOT of pictures, and I dread the thought of the hours
                    >>>>>> I'd have to spend with the pen tool to do a decent job with this.
                    >>>>>> and would appreciate any ideas on how I can remove that background
                    >>>>>> - the client wants a plain white behind the products. Thanks!
                    >>>>> easy and, most likely, provide the best solution.
                    >>>>> to me.
                    >>>>> Ilya Razmanov
                    >>>> ~ Bruce
                    >>> and use cards (black, white or gray) to help separate the object from
                    >>> the background. These "separators" would need to be positioned so
                    >>> they do not reflect in the product surface. This makes it quite easy
                    >>> to close cut the images with the magic wand or other matting tools.
                    >>> If a group arrangement is necessary, make sure that your background
                    >>> color choice does not appear in the products (white lids, white
                    >>> background) and also that the color is a neutral one, if the products
                    >>> following:
                    >>> flatten those two objects only. This will leave you with two objects,
                    >>> one much darker and the other normal.
                    >>> to select the background. You may have to alter the tolerance
                    >>> occasionally.
                    >>> or two.
                    >>> necessary.
                    >>> Hope this helps.
                    >> ~ Bruce
                    > Jim...
                    > I can't find a "Color Burn blend mode."
                    > ~ Bruce
                    Ah yes, I'm on CS 3 so that would be a problem. Basically, you're
                    looking for a blend mode that increases contrast and color saturation.
                    Multiply might do it.
                    • 7. Re: Removing Photo Background
                      Level 7
                      That is a neat technique Jim!
                      >>>> and would appreciate any ideas on how I can remove that background -
                      >>> me.
                      >>> Ilya Razmanov
                      >> ~ Bruce
                      > backdrop.
                      > following:
                      > two.
                      > necessary.
                      > Hope this helps.
                      • 8. Re: Removing Photo Background
                        Level 7
                        Jim,
                        Just wanted to update - I did find the Color Burn Blend tool -- that was
                        just User Error! I'm curious as to why your process takes the two layers and
                        flattens them into one? Seems like the same results could be accomplished
                        without the second layer... (no, I haven't tried it myself yet!) - what's
                        the rationale?
                        Thanks for taking the time to help! ;-)
                        ~ Bruce
                        >> following:
                        >> two.
                        >> necessary.
                        • 9. Re: Removing Photo Background
                          Level 7
                          • 10. Re: Removing Photo Background
                            Level 7
                            MrBruce wrote:
                            > Jim,
                            > and flattens them into one? Seems like the same results could be
                            > accomplished without the second layer... (no, I haven't tried it myself
                            > yet!) - what's the rationale?
                            > ~ Bruce
                            >>> following:
                            >>> occasionally.
                            >>> or two.
                            >>> necessary.
                            The difference is - I found - the wand doesn't really take into account
                            the blend so you're really just *wanding* the brightness/color values of
                            the original. When the two layers are flattened, my experience was that
                            the wand selection was faster/more accurate. But maybe I was just lucky :-)
                            • 11. Re: Removing Photo Background
                              Level 7
                              news:fbt1lf$6l7$2@forums.macromedia.com...
                              > MrBruce wrote:
                              >> Jim,
                              >> ~ Bruce
                              >>>> following:
                              >>>> occasionally.
                              >>>> two.
                              >>>> necessary.
                              Not lucky - SMART! It works very well, but I would never in a million years
                              have thought of using a second layer and flattening them!!! I was just
                              wondering why you thought to do it that way, and you just must have special
                              Fireworks instincts or something... Thanks again, Jim!
                              ~ Bruce
                              • 12. Re: Removing Photo Background
                                Level 7
                                >> MrBruce wrote:
                                >>> Jim,
                                >>> was just User Error! I'm curious as to why your process takes the two
                                >>> layers and flattens them into one? Seems like the same results could
                                >>> be accomplished without the second layer... (no, I haven't tried it
                                >>> myself yet!) - what's the rationale?
                                >>> ~ Bruce
                                >>>>>>>> the product photography for her. Having never done this before,
                                >>>>>>>> I assumed that I'd be able to use the Magic Wand to remove the
                                >>>>>>>> tool. I've tried some of the techniques from Linda's books, and
                                >>>>>>>> again, because there's not much contrast, I haven't had much
                                >>>>>>>> luck. There's a LOT of pictures, and I dread the thought of the
                                >>>>>>>> with this.
                                >>>>>>>> http://www.eranaturalbeauty.com/testing/, and would appreciate
                                >>>>> the following:
                                >>>>> objects, one much darker and the other normal.
                                >>>>> occasionally.
                                >>>>> pixel or two.
                                >>>>> if necessary.
                                >>>>> to further tweak the mask.
                                >> account the blend so you're really just *wanding* the brightness/color
                                >> values of the original. When the two layers are flattened, my
                                >> experience was that the wand selection was faster/more accurate. But
                                > years have thought of using a second layer and flattening them!!! I was
                                > just wondering why you thought to do it that way, and you just must have
                                > special Fireworks instincts or something... Thanks again, Jim!
                                > ~ Bruce
                                Just observations made while using the wand. It did not appear to be
                                making any better selections with the blended, unflattened layer than it
                                did with the normal layer. :-)
