7 Replies Latest reply on Apr 7, 2010 8:28 AM by WRobN1
    reCAPTCHA wont work...
    WRobN1
      I asked this on the reCAPTCHA forum as well.
      But because of the many people here i see more chance that i get my awnser here. (reCAPTCHA forum is a bit slow)
      I did a simple test to look if reCAPTCHA works.
      These following 2 PHP files; "form" and "verify" should work but dont.
      The reCap img shows but the verification goes wrong.
      It always result in this text:
      The reCAPTCHA wasn't entered correctly. Go back and try it again.
      (reCAPTCHA said: )
      This is my php test form (only recaptcha);
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://
      www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>Untitled Document</title>
      </head>
      <body>
      <form method="post" action="verify.php">
         <?php
           require_once('recaptchalib.php');
           $publickey = "xXxXxXxXxXxXxXxXx";
           echo recaptcha_get_html($publickey);
      </form>
      </body>
      </html>
      _____________________________________________
      And this the verify.php :
       <?php
       $privatekey = "xXxXxXxXxXxXxXxXx";
       $response = recaptcha_check_answer ($privatekey,
                                     $_SERVER["REMOTE_ADDR"],
                                     $_POST["recaptcha_challenge_field"],
                                     $_POST["recaptcha_response_field"]);
       if (!$resp->is_valid) {
         // What happens when the CAPTCHA was entered incorrectly
         die ("The reCAPTCHA wasn't entered correctly. Go back and try it
      again." .
              "(reCAPTCHA said: " . $resp->error . ")");
      The problem are the 2 php files above. They wont work and i dont know
      why.
      Its the basic code from the reCAP site.
      It should work but it doesnt.
      HELP!
      (I need to keep those 2 files seperated. An example from reCAPTCHA wich came with the library file works, but has both functions in the same file. And its different from the code i got from the recap site. The weirdest thing is that im not the only one using this code but probably one of the few who dont get it working.)
