13 Replies Latest reply on Apr 9, 2010 11:02 AM by hans-g.
    Page Title text box grayed out
    fender1952
      I created my website using a template and 2 Spry menubars (which is coming along
      fine) but something just happened that I can not name each page according to what it's content is.  When I try to change the title, it just keeps reverting back to, I think, what is on the index template page.  Is this possible?  Is it something that I did wrong?  Can I correct it??  Help!! Jo-Anne
        • 1. Re: Page Title text box grayed out
          jeremyluby Level 3
          Can you post the code of your template here?  We would just need to see the head area of the template.
          Thanks!
          • 2. Re: Page Title text box grayed out
            fender1952 Level 1
            Yikes - I'm sorry but I am not sure what you want.  Should I copy all the code of the .dwt (template page)???
            • 3. Re: Page Title text box grayed out
              jeremyluby Level 3
              Sure that will work.
              • 4. Re: Page Title text box grayed out
                fender1952 Level 1
                OK - here it is. Thanks.
                <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                <html xmlns="http://www.w3.org/1999/xhtml">
                <head>
                <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                <title>Ranco Dental Equipment</title>
                <style type="text/css">
                body  {
                font: 100% Verdana, Arial, Helvetica, sans-serif;
                background: #666666;
                margin: 0; /* it's good practice to zero the margin and padding of the body element to account for differing browser defaults */
                padding: 0;
                text-align: center; /* this centers the container in IE 5* browsers. The text is then set to the left aligned default in the #container selector */
                color: #000000;
                background-color: #e8e8e8;
                .twoColFixLtHdr #container {
                width: 850px;  /* using 20px less than a full 800px width allows for browser chrome and avoids a horizontal scroll bar */
                background: #FFFFFF; /* the auto margins (in conjunction with a width) center the page */
                border: 1px none #000000;
                text-align: left; /* this overrides the text-align: center on the body element. */
                margin-top: 0;
                margin-right: auto;
                margin-bottom: 0;
                margin-left: auto;
                padding: 0px;
                .twoColFixLtHdr #header {
                padding: 0 10px 0 20px;  /* this padding matches the left alignment of the elements in the divs that appear beneath it. If an image is used in the #header instead of text, you may want to remove the padding. */
                background-color: #41830b;
                border-top-style: none;
                border-right-style: none;
                border-bottom-style: none;
                border-left-style: none;
                .twoColFixLtHdr #header h1 {
                margin: 0; /* zeroing the margin of the last element in the #header div will avoid margin collapse - an unexplainable space between divs. If the div has a border around it, this is not necessary as that also avoids the margin collapse */
                padding: 10px 0; /* using padding instead of margin will allow you to keep the element away from the edges of the div */
                text-align: right;
                .twoColFixLtHdr #sidebar1 {
                float: left; /* since this element is floated, a width must be given */
                width: 220px;
                margin: auto;
                height: 430px;
                padding-top: 0px;
                padding-right: 5px;
                padding-bottom: 0px;
                padding-left: 5px;
                color: #000;
                background-color: #86B063;
                font-family: "Palatino Linotype", "Book Antiqua", Palatino, serif;
                font-size: 18px;
                font-weight: bold;
                .twoColFixLtHdr #mainContent {
                margin: 0 0 0 250px; /* the left margin on this div element creates the column down the left side of the page - no matter how much content the sidebar1 div contains, the column space will remain. You can remove this margin if you want the #mainContent div's text to fill the #sidebar1 space when the content in #sidebar1 ends. */
                padding: 0 20px; /* remember that padding is the space inside the div box and margin is the space outside the div box */
                .twoColFixLtHdr #footer {
                padding: 0;
                text-align: center;
                width: 850px;
                .twoColFixLtHdr #footer p {
                margin: 0; /* zeroing the margins of the first element in the footer will avoid the possibility of margin collapse - a space between divs */
                padding: 0px;
                text-align: center;
                .fltrt { /* this class can be used to float an element right in your page. The floated element must precede the element it should be next to on the page. */
                float: right;
                margin-left: 8px;
                .fltlft { /* this class can be used to float an element left in your page */
                float: left;
                margin-right: 8px;
                .clearfloat { /* this class should be placed on a div or break element and should be the final element before the close of a container that should fully contain a float */
                clear:both;
                    height:0;
                    font-size: 1px;
                    line-height: 0px;
                </style><!--[if IE 5]>
                /* place css box model fixes for IE 5* in this conditional comment */
                .twoColFixLtHdr #sidebar1 { width: 230px; }
                </style>
                <![endif]--><!--[if IE]>
                /* place css fixes for all versions of IE in this conditional comment */
                .twoColFixLtHdr #sidebar1 { padding-top: 30px; }
                .twoColFixLtHdr #mainContent { zoom: 1; }
                /* the above proprietary zoom property gives IE the hasLayout it needs to avoid several bugs */
                </style>
                <![endif]-->
                <script src="../SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
                <link href="../SpryAssets/SpryMenuBarVertical.css" rel="stylesheet" type="text/css" />
                .footer1 {
                font-size: 10px;
                font-style: italic;
                color: #FFF;
                font-weight: bold;
                text-align: left;
                </style>
                .header1 {
                font-size: 24px;
                font-style: italic;
                font-weight: bold;
                color: #000;
                text-align: left;
                .rancologotext1 {
                font-size: 36px;
                font-style: italic;
                font-weight: bold;
                color: #41830B;
                text-decoration: none;
                text-align: center;
                .body {
                font-size: 18px;
                font-style: italic;
                font-weight: bold;
                text-align: center;
                line-height: 20px;
                .bodyleft {
                font-size: 14px;
                font-style: italic;
                </style>
                <link href="../SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
                </head>
                <body class="twoColFixLtHdr">
                <div id="container">
                  <div id="header">
                    <h1><img src="../Images/Logo/Logo_chair_ProStar-gif.gif" width="720" height="144" alt="Ranco Dental Logo" /></h1>
                  <!-- end #header --></div>
                  <div id="sidebar1">
                    <ul id="MenuBar1" class="MenuBarVertical">
                      <li><a href="../index31.html">HOME</a>      </li>
                      <li><a href="../services3.html">SERVICES</a></li>
                      <li><a class="MenuBarItemSubmenu" href="../equipment3.html">EQUIPMENT</a>
                        <ul>
                          <li><a href="../equipmentnew3.html">NEW</a>          </li>
                          <li><a href="../equipmentused3.html">USED</a></li>
                </ul>
                      </li>
                      <li><a href="../parts3.html" class="MenuBarItemSubmenu">PARTS</a>
                        <ul>
                          <li><a href="#">AUTOCLAVES</a></li>
                          <li><a href="#">DRILLS</a></li>
                        </ul>
                      </li>
                      <li><a href="../aboutus3.html">ABOUT US</a></li>
                      <li><a href="../faqs3.html">FAQs</a></li>
                      <li><a href="../contactus3.html">CONTACT US</a></li>
                    </ul>
                    <h3> </h3>
                  <!-- end #sidebar1 --></div>
                <div id="mainContent">
                    <div class="header1"><!-- TemplateBeginEditable name="Welcome" -->
                      <p>Welcome to<br />
                                              <span class="rancologotext1">Ranco Denta<span class="rancologotext1">l</span></span><br />
                      </p>
                    <!-- TemplateEndEditable --></div>
                    <div class="rancologotext1"></div>
                    <div class="body"><!-- TemplateBeginEditable name="Main Content" -->It is our pleasure to be your single source for all your dental office needs and to provide you with the best customer experience and personalized service available.
                        <p class="body">You can count on Ranco to be there when you need us!</p>
                      <p class="body">Over 30 years experience!<br />
                          <br />
                      Dentists' most trusted partner for service, supplies,<br />
                      equipment &amp; technology!</p>
                      <p class="body"> </p>
                      <p class="body">~ Established 1986 ~<br />
                      </p>
                    <!-- TemplateEndEditable --></div></div>
                <div class="footer1" id="footer">
                <div class="MenuBarActive"></div>
                <ul id="MenuBar2" class="MenuBarHorizontal">
                  <li><a href="../equipment3.html" class="MenuBarItemSubmenu">EQUIPMENT</a>
                    <ul>
                      <li><a href="#">NEW</a></li>
                    </ul>
                  </li>
                  <li><a class="MenuBarItemSubmenu" href="../parts3.html">PARTS</a>
                    <ul>
                      <li><a class="MenuBarItemSubmenu" href="#">AUTOCLAVES</a>
                        <ul>
                          <li><a href="#">Item 3.1.1</a></li>
                          <li><a href="#">Item 3.1.2</a></li>
                        </ul>
                      </li>
                      <li><a href="#">LIGHT BULBS</a></li>
                    </ul>
                  </li>
                  <li><a href="../sitemap3.html">SITE MAP</a></li>
                </ul>
                <p> </p>
                <p><br />
                  </p>
                <p> </p>
                <p>Click here to contact the webmaster <a href="mailto:sail52@optonline.net">Angelsail</a><br />
                  This site created 2007, 2010<br />
                </p>
                <!-- end #footer --></div>
                <!-- end #container --></div>
                var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgRight:"../SpryAssets/SpryMenuBarRightHover.gif"});
                var MenuBar2 = new Spry.Widget.MenuBar("MenuBar2", {imgDown:"../SpryAssets/SpryMenuBarDownHover.gif", imgRight:"../SpryAssets/SpryMenuBarRightHover.gif"});
                </script>
                </body>
                </html>
                • 5. Re: Page Title text box grayed out
                  jeremyluby Level 3
                  Ok so the problem is that your title is not in an editable region.  You will need to create an editable region around your title, so that on individual pages that you want to have a title different than what you have in the template, you will be able to.
                  Do you know how to make editable regions?
                  J
                  • 6. Re: Page Title text box grayed out
                    fender1952 Level 1
                    I don't - not once it is an uneditable region. Will the fact that the 'Title' is a jpg be a problem?
                    • 7. Re: Page Title text box grayed out
                      bregent Most Valuable Participant
                      That doesn't make any sense. A page title can only be text. You can't use a jpg.
                      • 8. Re: Page Title text box grayed out
                        fender1952 Level 1
                        I see this <title>Ranco Dental Equipment</title> in the code.  Where is that coming from?  The only place I have 'Ranco Dental Equipment' is in a jpg logo in the header. I can't think it is written anywhere else.  So, if I have to make the header editable then what's the point of learning and using a template???
                        Jo-Anne
                        • 9. Re: Page Title text box grayed out
                          hans-g. Adobe Community Professional & MVP
                          copy the whole source code, create a new file, go to the source code and replace all commands (STRG A or CTRL A) with a copy of your template. After that you can edit the line <title>Ranco Dental Equipment</title> as I did for example with <title>test</title>.
                          Hans-G.
                          • 10. Re: Page Title text box grayed out
                            fender1952 Level 1
                            I looked through the
                            entire sorce code and don't find any of that code.
                            • 11. Re: Page Title text box grayed out
                              <html xmlns="
                              <head>
                              body  {
                              background: #666666;....
                              and so on.
                              And I would like to answer to this (your) question, I quote:
                              8. Apr 8, 2010 2:11 PM als Antwort auf: fender1952
                              Jo-Anne
                              Hans-G.
                              • 12. Re: Page Title text box grayed out
                                fender1952 Level 1
                                I am sorry...but I don't see what you'
                                re talking about with this   'go to the source code and replace all commands (STRG A or CTRL A) with a copy of your template.'
                                • 13. Re: Page Title text box grayed out
                                  Hi ok,
                                  1. create a new file
                                  2. got to the source code, it looks like that:
                                       <head>
                                       <title>Unbenanntes Dokument</title>
                                       </head>
                                       <body>
                                       </body>
                                       </html>
                                  3. Select all this by using "STRG A" or "CTRL A".
                                  4. Delete the selected text from Nr. 2.
                                  5. Open your template file
                                  6. Select the complete source code this by using "STRG A" or "CTRL A".
                                  7. Copy all by using "STRG C" or "CTRL C"
                                  8. Insert the the entire text into the blank file.
                                  9. Now you can edit the line <title>Ranco Dental Equipment</title> into your ideas.
                                  10. Save your file with its/a new name..
                                  Hans-G.
