3 Replies Latest reply on Apr 6, 2010 9:01 PM by JETalmage-71mYin
    problem with large amounts of grids
    Luke Thomas Smith
      Dear all
      I am constructing large scale pieces of work in illustrator using the grid tool.
      I am producing small duplicate grids which i colour to make up an image within the grids.
      The problem is when I get to a certain point I am told that there isn't enough memory to continue, therefore I am having to split the image into several documents which I then have lines up when I come to print.
      I want to do even smaller grids but that means more documents to line up and the printers hate me already!
      Is there a way to convert the grids when they are completed into something that takes up less memory so i can use one document?
        • 2. Re: problem with large amounts of grids
          JETalmage-71mYin Level 3
          It's difficult to advise without better explanation of how you are creating the grids and using them to constuct the artwork, the size & number of grids invloved, and the kind of artwork you are building. But on the face of it, it sounds like a poor workflow.
          So far, it almost sounds like you are drawing grids and filling them with color so as to make a mosaic that would be the vector equivilant to a raster image--a pointless excercise.
          Explain exactly and completely what you are doing, which tools you are using.
          • 3. Re: problem with large amounts of grids
            Wade_Zimmerman Level 6
            I made this a 24 x 36 inch document with each inch divided by 8.
            Then made it  live paint Group and use d the bucket to fill in areas by dragging over the areas rather than one square at a time.
            If you get rid of the strokes first before converting t a Live Paint group you have no spaces between the squares.
            IF you want you can draw a rectangle to the size you need then Go to Object >Path>Split into Grid and leave no space for the gutters then you have a grid as well that can be filled individually or as  part of a Live Paint Group.
            You can also go to Object> Expand and object flatten Transparency and that might help as well.
            The other thing you can do is every so often save the fie and quit and relaunch Illustrator.
