1 Reply Latest reply on Apr 6, 2010 1:25 PM by Virinao
    make an object act like a string & a movieClip
    Virinao
      The scenario is as follows:
      I have a movieClip on the stage called "home_btn" and another called "home".
      When moving over the home_btn movieClip I want the timeline inside of home to play. I used the slice command to get rid of the _btn which works fine, which is proven by the trace command, but it doesn't seem to be able to enter the timeline of home.
      home_btn.addEventListener(MouseEvent.MOUSE_OVER, onOver);
      function onOver(event:MouseEvent)
              var selectedButton:Object;
              var currentTarget:String = event.target.name;
              selectedButton = currentTarget.slice(0, currentTarget.indexOf("_"));
              trace(selectedButton);
              selectedButton.gotoAndPlay("over");
      The error message I get is this:
      TypeError:  Error #1006: value is not a function.
           at Version1_fla::MainTimeline/onOver()
      PS: I know the obvious way to make this work, but I want it to be mass-usable. Hence the complications.
      Thank you for you help,
      Virinao
        • 1. Re: make an object act like a string & a movieClip
          Virinao Level 1
          Solved!
          With the help of associative Arrays. It works like a mediator between a string and the movieClips which you have on your stage!
          var tempButton:Object = new Object;
          var mySlice:String;
          tempButton["home"] = home;
                  mySlice = currentTarget.slice(0, currentTarget.indexOf("_"));
                  trace(mySlice);
                  tempButton[mySlice].gotoAndPlay("over");
