0 Replies Latest reply on Aug 27, 2007 5:33 AM by bujjulu
    unable to set background color to an image ,that is  getting brightness to image using slider
    bujjulu
      unable to set background color to an image ,that is getting brightness to image using slider,,plzz help me here is the code for changing brightness of a box and how to apply on image
      <!-- http://blog.flexexamples.com/2007/08/24/adjusting-a-colors-brightness-using-the-colorutil- class/ -->
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      layout="vertical"
      verticalAlign="top"
      backgroundColor="white"
      creationComplete="changeColorChip()">
      <mx:Script>
      <![CDATA[
      import mx.utils.ColorUtil;
      private function changeColorChip():void {
      /* ColorUtil.adjustBrightness() takes a bright
      parameter between -255 and +255. */
      brite1 = slider.value;
      /* ColorUtil.adjustBrightness2() takes a bright
      parameter between -100 and +100. */
      brite2 = int(slider.value / 255 * 100);
      var adjustedColor1:uint = ColorUtil.adjustBrightness(rgb, brite1);
      var adjustedColor2:uint = ColorUtil.adjustBrightness2(rgb, brite2);
      colorStr1 = rgbToHex(adjustedColor1);
      box1.setStyle("backgroundColor", adjustedColor1);
      colorStr2 = rgbToHex(adjustedColor2);
      box2.setStyle("backgroundColor", adjustedColor2);
      private function rgbToHex(value:uint):String {
      var str:String = value.toString(16).toUpperCase();
      str = String("000000" + str).substr(-6);
      return str;
      private function reset():void {
      colorPicker.selectedIndex = 0;
      slider.value = 0;
      changeColorChip();
      </mx:Script>
      <mx:Number id="rgb">{colorPicker.selectedColor}</mx:Number>
      <mx:Number id="brite1" />
      <mx:Number id="brite2" />
      <mx:String id="colorStr1" />
      <mx:String id="colorStr2" />
      <mx:String id="lbl1">adjustBrightness(0x{rgbToHex(rgb)}, {brite1}) = 0x{colorStr1}</mx:String>
      <mx:String id="lbl2">adjustBrightness2(0x{rgbToHex(rgb)}, {brite2}) = 0x{colorStr2}</mx:String>
      <mx:ApplicationControlBar dock="true">
      <mx:Label text="RGB:" />
      <mx:ColorPicker id="colorPicker"
      change="changeColorChip()" />
      <mx:Spacer width="20" />
      <mx:Label text="Brightness:" />
      <mx:HSlider id="slider"
      minimum="-255"
      maximum="255"
      value="0"
      liveDragging="true"
      snapInterval="1"
      tickInterval="5"
      dataTipPrecision="0"
      width="100%"
      <mx:Button label="Reset"
      click="reset()" />
      </mx:ApplicationControlBar>
      <mx:HBox width="100%" height="100%">
      <mx:VBox width="50%" height="100%">
      <mx:Label text="{lbl1}"
      selectable="true" />
      <mx:Box id="box1"
      width="100%"
      height="100%" />
      </mx:VBox>
      <mx:Label text="{lbl2}"
      <mx:Box id="box2"
      width="100%"
      height="100%" />
      </mx:VBox>
      </mx:HBox>
      </mx:Application>
