3 Replies Latest reply on Apr 7, 2010 5:03 AM by Zabeth69
    Which template files need to be uploaded?
    jlm2009
      I have completed my web pages and want to upload to my host site.  I am confused as to which files must be uploaded.  I created a home page using a template, designated the areas to edit/not edit and created several other pages using the original page.  The original page is saved in the template folder as "default.dwt" and along the way I also ended up with a 'default.html" plus the other template-based pages saved as ".html".  The CSS code is external.  My question is do I upload the .dwt file and if so, should it be the home page?  Or is the appropriate code based in each html page and the .dwt file is not needed.  I don't recall seeing pages with a .dwt extension when I am surfing the web so thought perhaps the home page should be .html but wasn't sure if the .dwt page needs to be on-site to allow all the pages to work correctly.  Thanks for any help you can give me.
        • 1. Re: Which template files need to be uploaded?
          Zabeth69 Level 5
          Site structure:
          Root folder (holds all site files)
               index.html     NOT a template, this is the page that opens first when your url is entered, often called the "home page"
               otherfile.html
               otherfile2.html
               images folder
                    all images reside here
               Templates folder
                    all Templates reside here
               SpryAssets folder
                    all Spry assets (js and css files)
               css folder
                    other css files reside here
          Technically speaking, the Template (.dwt) file is a construction implement, not a display implement...you need it to build pages and to update the locked areas of pages based on it, but you do not SEE it when you look at a website. Keep your Templates within the site structure, for safekeeping, both online and on your local system. That way, if you have a failure on your local system, you will still have your pages and Templates available online for download.
          Speaking generally, presentation site pages are html, shtml, php, asp, etc., etc., but not dwt. You will find it helpful to name your files (no word spaces in file names, please) with meaningful names (not page1.html, or default.html, but contact_us.html, about_us.html, etc.)
          The Template file's first 'order of business' is to protect from inadvertent disaster the content that is repeated on multiple pages. You have set up such a Template, allowing editable areas. As you have seen, content in these editable areas may be different on every page, but such content is not contained in the Template.
          The Template file's 'second order of business' is to make it possible for you to easily alter those portions of pages that remain identical...those portions that are within the protected areas. Change the Template, save the revised Template, and the changes propagate to all the pages you based on the Template. All at once. Unique content is not changed, just the protected content, when a Template is updated. Then, the revised pages (all of them) are synchronized with your online site, and updated pages are uploaded to the server.
          Voila, the beauty of Templates.
          Beth
          • 2. Re: Which template files need to be uploaded?
            jlm2009 Level 1
            Thank you Beth, for a very clear explanation!  You answered my question and I can upload with confidence.
            • 3. Re: Which template files need to be uploaded?
              Zabeth69 Level 5
              You're welcome.
              Beth
