5 Replies Latest reply on Apr 14, 2010 6:38 AM by kglad
    How to test to see if inputted swf exists?
    celebritymusic Level 1
      Hi
      I have an input field that asks for a .swf name - you enter the name, hit SUBMIT, and Flash loads that .swf onto the screen.
      I've coded for an error to appear if the user doesn't input anything, but how to I test to see if the swf exists, and if not, return an error?
      I have a function called onSwfLoad that runs when the swf loader finishes, triggered by an Event.COMPLETE in the swf loader event listener - is there something I can put in an if statement there to test if the swf loader found a file?
      Thnaks
      Shaun
        • 1. Re: How to test to see if inputted swf exists?
          there's an ioerror event you can use.
          • 2. Re: How to test to see if inputted swf exists?
            Hi kglad
            How does IOErrorEvent.IO_ERROR fit into the following code?  I applied it as an event listener to the loader loading the swf, but I'm doing something wrong:
            loadSwfBut.addEventListener("mouseDown", sendData)
            function sendData(evt:Event)  {
                if(loadSwf.text !=""){
            var Xpos:Number = 0;
            var Ypos:Number = 100;
            var swf:MovieClip;
            var loader:Loader = new Loader();
            var defaultSWF:URLRequest = new URLRequest(loadSwf.text);
            loader.load(defaultSWF);
            loader.x = Xpos;
            loader.y = Ypos;
            addChild(loader);
                    loader.addEventListener(Event.COMPLETE, dataOnLoad);
                    loader.addEventListener(IOErrorEvent.IO_ERROR, errorLoading);
                } else status_txt.text = "All fields are mandatory"
            function errorLoading(event:IOErrorEvent):void {
                status_txt.text = "nup"
            function dataOnLoad(evt:Event){
                status_txt.text = "yep"
            stop()
            Thanks kglad
            Shaun
            • 3. Re: How to test to see if inputted swf exists?
              the loader class doesn't have any events.  you use the contentloaderinfo property of your loader to get a loaderinfo reference and that has the events you need:
              var swf:MovieClip;
              loader.x = Xpos;
              loader.y = Ypos;
              addChild(loader);
                      loader.contentLoaderInfo.addEventListener(Event.COMPLETE, dataOnLoad);
                      loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, errorLoading);
                  status_txt.text = "yep";
              stop();
              • 4. Re: How to test to see if inputted swf exists?
                Cheers kglad
                I'll try that in a few minutes.
                Much appreciated mate.
                Shaun
                • 5. Re: How to test to see if inputted swf exists?
                  you're welcome.
