9 Replies Latest reply on Apr 7, 2010 11:08 AM by FTQuest
    How to: not all corners are rounded
    de.hannes Level 1
      Is it possible to specify the rounded corners of a Box? Example: I only want to round the left-bottom and the  right-bottom corner.
      http://i41.tinypic.com/14mccg4.png
        • 1. Re: How to: not all corners are rounded
          David_F57 Level 5
          There is the right way and the easy way, below is the easy way - the right way is to use a path(svg) to draw your border then set your color fill.
          David.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <s:Group top="100" left="100" bottom="100" right="100">
          <s:Rect left="0" right="0" top="0" bottom="40">
          <s:stroke>
          <s:SolidColorStroke color="#555555" />
          </s:stroke>
          <s:fill>
          <s:SolidColor color="#C0C0C0" />
          </s:fill>
          </s:Rect>
          <s:Rect left="0" right="0" height="80" bottom="0" radiusX="20" radiusY="20" >
          <s:stroke>
          </s:stroke>
          <s:fill>
          <s:SolidColor color="#C0C0C0"/>
          </s:fill>
          </s:Rect>
          <s:Rect left="1" right="1" top="1" bottom="40">
          <s:fill>
          </s:fill>
          </s:Rect>
          </s:Group>
          </s:Application>
          • 2. Re: How to: not all corners are rounded
            de.hannes Level 1
            Ha, Ok! But theire is no way to do this as a property for a Box, like a Canvas, HBox, and so on? Is theire a way how i can extend a box to implement this property? Which internal methode draws the shape of a box?
            • 3. Re: How to: not all corners are rounded
              David_F57 Level 5
              hi,
              Ideally you create a skin for the component i.e. a skinnable container and either do it the way above with a bit cleaner code or you use svg path to draw the border, I did this before with options for each corner, i'll find the code and attach it later tonight when i have a bit of time.
              David
              • 4. Re: How to: not all corners are rounded
                FTQuest Level 3
                Why not to use the 'bottomLeftRadiusX', 'bottomLeftRadiusY' and similar attributes of Rect to define the corners individually?
                FTQuest
                • 5. Re: How to: not all corners are rounded
                  David_F57 Level 5
                  Hey FTQuest,
                  And there's that
                  I forgot about those additions rect, we all get something from these forums ....
                  thanks.
                  David.
                  • 6. Re: How to: not all corners are rounded
                    de.hannes Level 1
                    Which component has such properties? I can't find them in the docs. How can I use them?
                    • 7. Re: How to: not all corners are rounded
                      David_F57 Level 5
                      Any component than can be skinned can have rounded corners.(this is for Flashbuilder with flex 4 sdk)
                      1. create a new project, drop a skinnable container onto the form in design view
                      2. right click on the container and select create skin
                      3 you can then edit that new skin to round your corners.
                      the following is a modified container skin - modified area marked in green
                      Once you have this skin you can use it for any other container you add to your application
                      <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
                          xmlns:fb="http://ns.adobe.com/flashbuilder/2009" alpha.disabled="0.5">
                          <fx:Metadata>
                          <![CDATA[
                              [HostComponent("spark.components.SkinnableContainer")]
                          </fx:Metadata>
                          <fx:Script fb:purpose="styling">
                              <![CDATA[
                                   *  @private
                                  override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number) : void
                                      if (isNaN(getStyle("backgroundColor")))
                                          background.visible = false;
                                      else
                                          background.visible = true;
                                          bgFill.color = getStyle("backgroundColor");
                                          bgFill.alpha = getStyle("backgroundAlpha");
                                      super.updateDisplayList(unscaledWidth, unscaledHeight);
                          </fx:Script>
                          <s:states>
                              <s:State name="normal" />
                              <s:State name="disabled" />
                          </s:states>
                          <!--- Defines the appearance of the SkinnableContainer class's background. -->
                          <s:Rect id="background" left="0" right="0" top="0" bottom="0" bottomLeftRadiusX="20" bottomRightRadiusX="20" bottomLeftRadiusY="20" bottomRightRadiusY="20">
                      <s:stroke>
                      <s:SolidColorStroke color="#000000" weight="2"/>
                      </s:stroke>
                             <s:fill>
                                   <s:SolidColor id="bgFill" color="#FFFFFF"/>
                              </s:fill>
                          </s:Rect>
                      <s:Group id="contentGroup" left="0" right="0" top="0" bottom="0" minWidth="0" minHeight="0">
                              <s:layout>
                                  <s:BasicLayout/>
                              </s:layout>
                          </s:Group>
                      </s:Skin>
                      • 8. Re: How to: not all corners are rounded
                        de.hannes Level 1
                        Ok, I got it! I thought there should be an easy programmatically way to do this for my special component. Well, the skinning method should be the right.
                        Thanks guys.
                        • 9. Re: How to: not all corners are rounded
                          FTQuest Level 3
                          Here is fairly short version:
                          <s:Rect x="20" y="20" width="200" height="100" bottomLeftRadiusX="20" bottomLeftRadiusY="20" bottomRightRadiusX="20" bottomRightRadiusY="20" >
                          <s:stroke>
                          <s:SolidColorStroke color="0xFF0000" weight="2" />
                          </s:stroke>
                          </s:Rect>
                          </s:Application>
