4 Replies Latest reply on Apr 13, 2010 1:13 AM by pogla129
    Image from database....showing as black image
    pogla129
      I am new in flex.
      I want  to display a flex image from database.The image is saved from flex to the server side Servlet to  oracle data base.When i retrieving the image from the data base with the help of servlet  to a flex page it shows black image .
                                                       Any one can help me  to solve the problem....................  code related to the application is given blpw
      From  mxml application from which I am sending the image to the servlet
      var
      dd:URLVariables=new URLVariables();
      var bitmapData3:BitmapData=new BitmapData(sImage3.width, sImage3.height, true, 0xffffff);
      var encode3:JPEGEncoder = new JPEGEncoder(100);
      var ping3:ByteArray = encode3.encode(bitmapData3);
      var be3:Base64Encoder = new Base64Encoder();
      be3.encodeBytes(ping3);
      var jpegToStrg:String=new String();
      jpegToStrg = be3.flush().toString();
      dd.pictr=jpegToStrg;
      var request:URLRequest = new URLRequest("http://"+pop.Url()+"/ProjectNew/FirmRegistrationServlet");
      request.method=URLRequestMethod.POST;
      request.data = dd;
      In the  servlet file where image is saved to data base
      byte[] image1 = new byte[42015];
      image1 = request.getParameter(
      "pic").getBytes();
      tsql
      = "INSERT INTO PERNEWADMIN.spon_firm (SPON_FIRM_CD,SPON_FIRM_NAME,ADDR1, ";
      tsql += " AUTH_SIGNATURE1_IMAGE,
      tsql += " ) VALUES(?,?,?,?,?,)";
      ps = tcon.prepareStatement(tsql);
      ps.setString(1, firm_cd);
      ps.setString(2, SF.getSpon_firm_name());
      ps.setString(3, SF.getAddr1());
      ps.setBytes(12, image1 )   ///Here is the image variable
      ps.execute();
      Image is saved successfully
      Given blow the the servlet from where  i want to select the image.............
      out.print("<?xml version=\"1.0\"?>\n");
      out.print("<table>");
      out.print("<image>");
      Blob blobSign1 =
      null;
      tsql
      = "SELECT auth_signature1_image,auth_signature2_image,auth_signature3_image FROM pernewadmin.spon_firm ";
      tsql += " WHERE spon_firm_name LIKE 'hhh' ";
      // ps.setString(1, fname);
      rs = ps.executeQuery();
      while (rs.next()) {
      blobSign1 =
      rs.getBlob("auth_signature1_image");
      int length = (int) blobSign1.length();
      byte[] buffer = new byte[length];
      BufferedInputStream bis =
      null;
      bis =
      new BufferedInputStream(blobSign1.getBinaryStream());
      while ((length = bis.read(buffer)) != -1) {
      out.write(buffer, 0, length);
      out.print("</image>");
      out.print("</table>");
      Given below the mxml page where i want show the image
      private function resultGetFirmDetails(event:ResultEvent):void{
      try{
      var xmldata1:XML=event.result as XML;
      var byteData : ByteArray=new ByteArray();
      var deccoder : Base64Decoder = new Base64Decoder();
      deccoder.decode(xmldata1.image);
      byteData = deccoder.toByteArray();
      sImage1.visible=
      true;
      sImage1.source=byteData; // here a black image is displayed
      catch( ex : Error )
      Alert.show(
      "Error:In .xmnl file" );
