2 Replies Latest reply on Apr 13, 2010 11:42 AM by Niko Miranowicz
    Strange rendering while rotating blended objects...
    Niko Miranowicz
      Hello,
      I have a problem (I posted it also elsewhere but hoping for broader solution). I am creating a simulation application with cylindrical object representing glass which are moved around and rotated. When such glassy object is inside another while rotating the world it seems like its surface is inverting. I have prepared simplified example of this (http://zdch.amu.edu.pl/director/pr4.html, http://zdch.amu.edu.pl/director/pr4.dir) with a stack of cylinders with blend 60 that are in interposition with another cylinder. During animation, when seen at front for some short time one can notice a change (http://zdch.amu.edu.pl/director/Picture.png) half of the cylinders in the stack are in front of the big one and three steps further they are in the back while the other half of the stack appears in the front. As far as I tested it doesn't depend on the renderer. It may be reproduced with this code in two following frames and a 3dworld...
      first frame:
      on exitFrame me
        wd=sprite(2).member
        member(1).resetworld()
        mr=sprite(2).member.newmodelresource("mr", #cylinder, #both)
        mr.bottomRadius = 5
        mr.topRadius = 5
        mr.height = 30
        mm=wd.newmodel("ml", mr)
        mm.transform.position=vector(0,0,0)
        mm.transform.scale=vector(5,5,5)
        ml=list()
        wd.shader[1].blend=60
        repeat with a=1 to 10
          ml[a]=wd.newmodel("ml"&a, mr)
          ml[a].transform.position=vector(25,a*15-100,0)
          ml[a].transform.scale=vector(5,0.5,5)
        end repeat
      end
      second frame:
      on exitFrame me   member("lab").camera(1).rotate(vector(1,0,0),#world)
      go to the frame
      end
      Thank you for help or comments
      Nikodem
