2 Replies Latest reply on Apr 7, 2010 11:00 PM by Vikranthflex4
    Flex4  E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\... WHY
    Vikranthflex4
      HI,
      I have migrated from flex 4 beta to Flex 4 version and when i run my application ,i see some run time errors pointing to E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\...
      Strange why.......
      Any help pls...
      V
        • 1. Re: Flex4  E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\... WHY
          msakrejda Level 4
          That's the path of the source files used to compile the official build of the framework. This is normal in how Flash reports errors. As to why you're seeing the errors, you'd need to tell us about the error messages themselves.
          • 2. Re: Flex4  E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\... WHY
            Vikranthflex4 Level 1
            I could see the below error message why?
            ArgumentError: Error #2004: One of the parameters is invalid.
                at flash.display::Graphics/drawRoundRect()
                at spark.primitives::Rect/draw()[E:\dev\4.0.0\frameworks\projects\spark\src\spark\primitives \Rect.as:459]
                at spark.primitives.supportClasses::StrokedElement/updateDisplayList()[E:\dev\4.0.0\framewor ks\projects\spark\src\spark\primitives\supportClasses\StrokedElement.as:143]
                at spark.primitives.supportClasses::GraphicElement/http://www.adobe.com/2006/flex/mx/internal::doUpdateDisplayList()[E:\dev\4.0.0\frameworks\ projects\spark\src\spark\primitives\supportClasses\GraphicElement.as:3828]
                at spark.primitives.supportClasses::GraphicElement/validateDisplayList()[E:\dev\4.0.0\framew orks\projects\spark\src\spark\primitives\supportClasses\GraphicElement.as:3812]
                at spark.components::Group/updateDisplayList()[E:\dev\4.0.0\frameworks\projects\spark\src\sp ark\components\Group.as:956]
                at spark.skins::SparkSkin/updateDisplayList()[E:\dev\4.0.0\frameworks\projects\spark\src\spa rk\skins\SparkSkin.as:191]
                at mx.skins.spark::SparkSkinForHalo/updateDisplayList()[E:\dev\4.0.0\frameworks\projects\spa rkskins\src\mx\skins\spark\SparkSkinForHalo.as:118]
                at mx.skins.spark::ButtonSkin/updateDisplayList()[E:\dev\4.0.0\frameworks\projects\sparkskin s\src\mx\skins\spark\ButtonSkin.mxml:66]
                at mx.core::UIComponent/validateDisplayList()[E:\dev\4.0.0\frameworks\projects\framework\src \mx\core\UIComponent.as:8531]
                at mx.managers::LayoutManager/validateClient()[E:\dev\4.0.0\frameworks\projects\framework\sr c\mx\managers\LayoutManager.as:932]
                at mx.core::UIComponent/validateNow()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core \UIComponent.as:7631]
                at mx.controls::Button/http://www.adobe.com/2006/flex/mx/internal::viewSkinForPhase()[E:\dev\4.0.0\frameworks\pro jects\framework\src\mx\controls\Button.as:1963]
                at mx.controls::Button/http://www.adobe.com/2006/flex/mx/internal::viewSkin()[E:\dev\4.0.0\frameworks\projects\fr amework\src\mx\controls\Button.as:1869]
                at mx.controls::Button/commitProperties()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\ controls\Button.as:1615]
                at mx.core::UIComponent/validateProperties()[E:\dev\4.0.0\frameworks\projects\framework\src\ mx\core\UIComponent.as:7772]
                at mx.managers::LayoutManager/validateProperties()[E:\dev\4.0.0\frameworks\projects\framewor k\src\mx\managers\LayoutManager.as:572]
                at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\managers\LayoutManager.as:700]
                at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.0.0\frameworks\projec ts\framework\src\mx\managers\LayoutManager.as:1072]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at ModuleInfoProxy/moduleEventHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\mo dules\ModuleManager.as:1168]
                at ModuleInfo/readyHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\modules\Modul eManager.as:812]
                at mx.core::FlexModuleFactory/update()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cor e\FlexModuleFactory.as:433]
                at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\4.0.0\frameworks\projects\framework\s rc\mx\core\FlexModuleFactory.as:582]
                at mx.core::FlexModuleFactory/docFrameListener()[E:\dev\4.0.0\frameworks\projects\framework\ src\mx\core\FlexModuleFactory.as:126]
