3 Replies Latest reply on Apr 7, 2010 6:53 PM by David_F57
    FLEX vs FLASH 'performance'
    rhythmone
      I work for a rather large entertainment company, and I am being referred to this doc:
      http://www.adobe.com/devnet/flex/articles/client_perf/client_server_performance.pdf
      With this callout:
      "SWF File Sizes with Flex SDK  – in the past SDK-based apps have resulted in large .swf files. This is because the Flex SDK MUST be downloaded to the flash player client. In Flex 2 and lower this could only be done by embedding the Flex SDK into the SWF, resulting in a must larger SWF (and performance hit each time it was downloaded to the client). As of Flex 3, versions of the SDK must only be downloaded by a user once where they will be cached and used across domains."
      Can someone here elaborate on this.... as this is being disseminated as a reason to stay away from using FLEX.
        • 1. Re: FLEX vs FLASH 'performance'
          msakrejda Level 4
          The technique in general is called RSL (something Shared Library, I believe). I haven't worked with them personally, but if no one chimes in here, you should be able to find more specific information by searching for RSLs and Flex. I believe linking against the framework is through the RSL mechanism by default in Flex 4.
          • 2. Re: FLEX vs FLASH 'performance'
            SpaghettiCoder Level 3
            Site1, Site2, Site3, Site4 all done with the framework.
            If a user was to visit these sites before, then the framework would've been downloaded 4 times.
            Now what would happen is once the user visits 1 of the sites, the framework is downloaded that 1 time and can be used by the other 3 sites without having to redownloading the complete framework 3 more times..
            FX4 has that ON as default
            With FX3 you had to actually to change some options for it to do that.
            • 3. Re: FLEX vs FLASH 'performance'
              David_F57 Level 5
              As previously stated runtime shared libraries are about reducing bandwidth consumption, one way to gauge this is to look at the size of you app(swf) compiled with rsl against a swf compiled with merge code.
              A simple merged code app maybe around 450k as a standalone swf and about 150k as a swf using RSL, in this instance the merge option maybe a better choice for low return customer hits as the complete RSL libraries are about 1.5mb.
              When you use merge code to build your project only the required parts of the sdk are merged into your swf.
              My own thoughts are if it is a true RIA that will have multiple hits from the same user(client) then RSL is the better option as subsequent startup times for the app will be significantly better.
              Another benefit of RSL's is that they are not in the regular browser cache but are cached by flashplayer itself so you don't lose RSL's if the browser cache is cleared.
              David
