0 Replies Latest reply on Apr 7, 2010 4:31 PM by Paul Reilly
    [svn:fx-trunk] 15269:
    Paul Reilly
      Revision: 15269
      Revision: 15269
      Author:   preilly@adobe.com
      Date:     2010-04-07 16:30:58 -0700 (Wed, 07 Apr 2010)
      Log Message:
      • Added javadoc to flex2.compiler package.  While documenting
        LicenseException, I realized it was dead code, so I removed it.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey (post-checkin)
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/tests/basicTests/dmv/views/ODGTests.mxml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/AbstractDelegatingSubCompiler.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/AbstractSubCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/AssetInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Assets.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/FileSpec.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/ILocalizableMessage.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Logger.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PersistenceStore.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/ResourceBundlePath.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/ResourceContainer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourceList.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourcePath.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Transcoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/TranscoderException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/CompilerMessage.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/package.html
      Removed Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/LicenseException.java
