1 Reply Latest reply on Sep 11, 2007 11:15 AM by peterent
    Loading a server side flex movie into a client side flex application
    Dzihan
      Hello all,
      I'm running a local flex application that's loading another flex movie from an external url into a container (via SWFLoader).
      After setting up the whole crossdomain.xml issue, i'm facing a weird problem:
      The loaded swf shows up streched and does not inherit any styles from the parent application. It also can not trigger any function inside the parent application or the other way round.
      When i load the same swf from my local filestore everything is fine. It's also working properly when i load the parent application from the same webserver the "loadin" swf comes from...
      Does anyone know the problem? How can this be solved? Can it be solved? If not, i'm in trouble..
      Best regards,
      N.
