0 Replies Latest reply on Apr 7, 2010 5:05 PM by Carol L. Frampton
    [svn:fx-4.x] 15270: remeasureText() should not remeasure if the text is constrained in both directions.
    Carol L. Frampton Level 2
      Revision: 15270
      Revision: 15270
      Author:   cframpto@adobe.com
      Date:     2010-04-07 17:05:48 -0700 (Wed, 07 Apr 2010)
      Log Message:
      remeasureText() should not remeasure if the text is constrained in both directions.  Determine if the text is constrained by using the values passed to setLayoutBoundsSize() rather than comparing with the measured values.  Before this change the code did not recognize a constrained value if it was the same as the measured value.
      QE notes:
      Doc notes: None
      Bugs:  SDK-25423
      Reviewed By: Gordon
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25423
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/RichEditableText.as
