1 Reply Latest reply on Jun 5, 2010 3:20 AM by Adam Cameron.
    Editing XSD file is dreadfully slow
    Adam Cameron. Level 5
      G'day
      I'm currently editing an XSD file, and CFB is really struggling to keep up with my typing.  If - for example - I type this:
      <!-- this is an example of how bloody slow this thing is!! -->
      By the time I'm finished, CFB has only actually displayed it as far as:
      And I can watch it insert the rest of the chars at a rate of about three every two seconds.
      The XSD file is only 130 lines long - 4.5kB - about 25% of which is whitespace or comments.
      Has anyone else noticed this?
      It's a stand-alone CFB install, on a Win7 Starter netbook.  I do not have similar problems with other (much larger) files.  Just this XSD file (it's the only XSD file I have to hand, so cannot test another one).
      I've found that I get a bit of a slow-down on large (1500+ lines) CFCs, but even then it's nothing as slow as this.
      Adam
        • 1. Re: Editing XSD file is dreadfully slow
          Note: it's even worse with a .htaccess file.  CFB will - "reliably" - freeze-up for up for around 30sec when I first open a .htaccess file, and will also "stutter" for a few seconds at a time fairly frequently when scrolling around in it, or making changes.
          If I change the file association to not use the CF perspective for .htaccess files, instead using the default editor, it seems to be OK.
          Note: this is not the case with XSD files... they're just slow even on the XML perspective.
          Adam
