1 Reply Latest reply on Sep 11, 2007 11:08 AM by peterent
    How do I load a component?
    Spyder211
      I have a component from the exchange that im trying to use. How do I load/activate it?
        • 1. Re: How do I load a component?
          peterent Level 2
          The component is either contained in a .SWC or it is source code. If you have a .SWC, place it into a directory and included the SWC in your Flex source path. From Flex Builder, pick Project Properties->Flex Build Path; chose the Library tab, pick "Add SWC" button and navigate to the SWC file.
          if you have source code, then pick Project Properties->File Build Path, chose Source tab, and add the directory of the code.
