0 Replies Latest reply on Apr 8, 2010 8:10 AM by jlm226
    Issues with Spry menu bar
    jlm226
      I am in the process of redesigning my company's website and am having issues with the Spry menu bar.
      The first issue has to do with alignment. In the main row of the menu bar, I want everything to be centered but on the submenus, I want them to be aligned to the left. The first submenu is aligned the way I want it to be, the second one is aligned to the left but with a bigger margin and the last one (under Publications) is centered. How do I get a consistent look for each submenu?
      The second issue involves font size. I want to make the font bigger in my menu bar because it looks really small in the browser (Explorer) but when I make the font bigger, it bumps the menu bar onto a second row. Is there a way I can enlarge the font without having it go to a second row? Also, the button Human Resources is two lines, I used the 'no-wrap' feature but it still does this. How can I fix that?
      Also, if I want to have this menu bar on all the pages, can I just copy and paste or is there something else I have to do?
      I've included Spry menu bar code so you can see what I'm talking about.
      Spry menu bar:
      * The outermost container of the Menu Bar, an auto width box with no margin or padding */
      ul.MenuBarHorizontal
      margin: 0;
      padding: 0;
      list-style-type: none;
      font-size: 100%;
      cursor: default;
      width: 900px;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
      z-index: 1000;
      /* Menu item containers, position children relative to this container and are a fixed width */
      ul.MenuBarHorizontal li
      margin: 0;
      padding: 0;
      font-size: 11px;
      position: inherit;
      text-align: center;
      cursor: pointer;
      width: 11
      ..5em;
      float: left;
      white-space: nowrap;
      width: 11em;
      font-weight: 900;
      /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarHorizontal ul
      margin: 0;
      padding: 0;
      font-size: 100%;
      z-index: 1020;
      cursor: default;
      width: 13em;
      position: absolute;
      left: -1000em;
      background-color: #FCB035;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
      left: auto;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarHorizontal ul li
      width: 8.2em;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
      ul.MenuBarHorizontal ul ul
      position: absolute;
      margin: -5% 0 0 95%;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
      left: auto;
      top: 0;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Submenu containers have borders on all sides */
      border: 1px solid #CCC;
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarHorizontal a
      display: block;
      cursor: pointer;
      padding: .8em .8em;
      color: #333;
      text-decoration: none;
      font-family: Arial, Helvetica, sans-serif;
      font-size: 11px;
      font-variant: small-caps;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
      color: #FFF;
      font-size: 11px;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
      color: #FFF;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
      background-repeat: no-repeat;
      background-position: 95% 50%;
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
      background-image: url(SpryMenuBarRight.gif);
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
      background-image: url(SpryMenuBarDownHover.gif);
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
      background-image: url(SpryMenuBarRightHover.gif);
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarHorizontal iframe
      position: absolute;
      z-index: 1010;
      filter:alpha(opacity:0.1);
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      @media screen, projection
      ul.MenuBarHorizontal li.MenuBarItemIE
      background: #FFF;
