8 Replies Latest reply on Apr 13, 2010 2:27 AM by Harm Millaard
    Having problem with video compression
    hoaken2
      I have search thru the web for the answer to this question but with no luck.
      I am simply trying to compress a video tutorial so the text on the video can be read therefore I need a good quality video. Frame dropping will not be a problem.
      The video is created in Premiere CS4 and compressed in Media Encoder. I can not get Media Encoder to do the simpliest things. Compression with AE seems to be much better.
      As a test, I wanted to export the largest possible file just to make sure I can get the quality. Once that is achieved I would then reduce the file size.
      These are the settings that I am trying to export.
      Video Codec:      H 2.64
      Quality:              100
      Width:                1440
      Height:               900
      Frame Rate:        15
      Field type:           Progressive
      Aspect Ratio:      Square
      Key Frame Distance:     1
      Set Bitrate:     144,00kps (maximum I could get)
      Surely this setting would be almost near to uncompressed and therefore sharp. However, I get a really blurry soft video. I checked the video but the bit rate is only 1.47Mbits/sec! I would rather it have a bit rate of 5Mbits/sec and have a sharper image.
      Any thoughts?
