0 Replies Latest reply on Apr 8, 2010 9:19 AM by zoogeny
    Does Flash IDE compiler follow symlinks?
    zoogeny
      I am using Flash CS4 10.0.2 on OS X 10.6.3.
      I have a Flash project in a dir:
      $ ll
      -rw-r--r--@ 1  jfassett   jfassett   4.5K  8 Apr 18:04 Navigation.as
      -rw-r--r--@ 1  jfassett   jfassett    59K  8 Apr 16:44 Navigation.fla
      -rw-r--r--@ 1  jfassett   jfassett   547B  8 Apr 18:05 Navigation.swf
      lrwxr-xr-x  1  jfassett  jfassett    29B  8 Apr 18:05 com -> /project/kiln/as3lib/src/com/
      -rw-r--r--@ 1  jfassett   jfassett   563B  8 Apr 17:55 data.xml
      You can see I have the directory com as a symlink to another location on my hd. If I try and import files from the com directory into Navigation.as the Flash IDE cannot find them saying:
      1172: Definition com.zoogeny.resource:ResourceService could not be found.
      It works using mxmlc:
      $ mxmlc Navigation.as
      Loading configuration file /Applications/Adobe Flash Builder Beta 2/sdks/3.4.1/frameworks/flex-config.xml
      /Users/jfassett/Documents/_work/freelance/fdsdevelopments/Navigation.swf (4434 bytes)
      Should the Flash IDE also be following the symlinks?
