3 Replies Latest reply on Apr 9, 2010 6:55 AM by JeffryHouser
    AutoComplete ComboBox
    sundaresan@J2se
      Hi All,
                I am using AutoComplete ComboBox,right now it displays the matching options based on the typed input value. is it possible to display the entire list and highlight the matching option based on the user text???
      Regards,
      Sundar
        • 1. Re: AutoComplete ComboBox
          JeffryHouser Level 4
          Which AutoCompleteComboBox are you using?
          With the Flextras one ( http://www.flextras.com/?event=ProductHome&productID=10 ), you should be able to cancel the the autoCompleteDataPRoviderFilterBegin event and cancel it to prevent the internal filtering from taking effect.
          Docs: http://www.flextras.com/AutoCompleteComboBox/docs/asdocs/com/flextras/autoCompleteComboBox /AutoCompleteComboBox.html#event:autoCompleteDataProviderFilterBegin  )
          You could also replace the autoCompleteFilterFunction with something that returns true for all items no matter what the user types.
          Docs: http://www.flextras.com/AutoCompleteComboBox/docs/asdocs/com/flextras/autoCompleteComboBox /AutoCompleteComboBox.html#autoCompleteFilterFunction
          Of course, I would say this behavior is inconsistent with the way most AutoComplete's work and may confuse users.
          • 2. Re: AutoComplete ComboBox
            sundaresan@J2se Level 1
            Thanks for the reply ,
            I have extended the Flex mx.controls.ComboBox to achieve this. Code is given below... it will be useful to understand ,mean i try your suggestions.
            //  Copyright (C) 2003-2006 Adobe Macromedia Software LLC and its licensors.
            //  All Rights Reserved. The following is Source Code and is subject to all
            //  restrictions on such code as contained in the End User License Agreement
            //  accompanying this product.
            package com.adobe.flex.extras.controls
            import flash.events.Event;
            import flash.events.FocusEvent;
            import flash.events.KeyboardEvent;
            import flash.net.SharedObject;
            import flash.ui.Keyboard;
            import mx.collections.ListCollectionView;
            import mx.controls.ComboBox;
            import mx.core.UIComponent;
            import mx.controls.Alert;
            //  Events
            *  Dispatched when the <code>filterFunction</code> property changes.
            *  You can listen for this event and update the component
            *  when the <code>filterFunction</code> property changes.</p>
            *  @eventType flash.events.Event
            [Event(name="filterFunctionChange", type="flash.events.Event")]
            *  Dispatched when the <code>typedText</code> property changes.
            *  when the <code>typedText</code> property changes.</p>
            [Event(name="typedTextChange", type="flash.events.Event")]
            //  Excluded APIs
            [Exclude(name="editable", kind="property")]
            *  The AutoComplete control is an enhanced
            *  TextInput control which pops up a list of suggestions
            *  based on characters entered by the user. These suggestions
            *  are to be provided by setting the <code>dataProvider
            *  </code> property of the control.
            *  @mxml
            *  <p>The <code>&lt;fc:AutoComplete&gt;</code> tag inherits all the tag attributes
            *  of its superclass, and adds the following tag attributes:</p>
            *  <pre>
            *  &lt;fc:AutoComplete
            *    <b>Properties</b>
            *    keepLocalHistory="false"
            *    lookAhead="false"
            *    typedText=""
            *    filterFunction="<i>Internal filter function</i>"
            *    <b>Events</b>
            *    filterFunctionChange="<i>No default</i>"
            *    typedTextChange="<i>No default</i>"
            *  /&gt;
            *  </pre>
            *  @includeExample ../../../../../../docs/com/adobe/flex/extras/controls/example/AutoCompleteCountriesData/A utoCompleteCountriesData.mxml
            *  @see mx.controls.ComboBox
            public class AutoCompleteModified extends ComboBox
                //  Constructor
                 *  Constructor.
                public function AutoCompleteModified()
                    super();
                    //Make ComboBox look like a normal text field
                    editable = true;
                    if(keepLocalHistory)
                        addEventListener("focusOut",focusOutHandler);
                    setStyle("arrowButtonWidth",0);
                    setStyle("fontWeight","normal");
                    setStyle("cornerRadius",0);
                    setStyle("paddingLeft",0);
                    setStyle("paddingRight",0);
                    rowCount = 7;
                //  Variables
                 *  @private
                private var cursorPosition:Number=0;
                 *  @private
                private var prevIndex:Number = -1;
                 *  @private
                private var removeHighlight:Boolean = false;
                 *  @private
                private var showDropdown:Boolean=false;
                 *  @private
                private var showingDropdown:Boolean=false;
                 *  @private
                private var tempCollection:Object;
                 *  @private
                private var usingLocalHistory:Boolean=false;
                 *  @private
                private var dropdownClosed:Boolean=true;
                //  Overridden Properties
                //  editable
                 *  @private
                 override public function set editable(value:Boolean):void
                    //This is done to prevent user from resetting the value to false
                    super.editable = true;
                 *  @private
                 override public function set dataProvider(value:Object):void
                    super.dataProvider = value;
                    if(!usingLocalHistory)
                        tempCollection = value;
                //  labelField
                 *  @private
                 override public function set labelField(value:String):void
                    super.labelField = value;
                    invalidateProperties();
                    invalidateDisplayList();
                //  Properties
                //  filterFunction
                 *  @private
                 *  Storage for the filterFunction property.
                private var _filterFunction:Function = defaultFilterFunction;
                 *  @private
                private var filterFunctionChanged:Boolean = true;
                [Bindable("filterFunctionChange")]
                [Inspectable(category="General")]
                 *  A function that is used to select items that match the
                 *  function's criteria.
                 *  A filterFunction is expected to have the following signature:
                 *  <pre>f(item:~~, text:String):Boolean</pre>
                 *  where the return value is <code>true</code> if the specified item
                 *  should displayed as a suggestion.
                 *  Whenever there is a change in text in the AutoComplete control, this
                 *  filterFunction is run on each item in the <code>dataProvider</code>.
                  *  <p>The default implementation for filterFunction works as follows:<br>
                  *  If "AB" has been typed, it will display all the items matching
                 *  "AB~~" (ABaa, ABcc, abAc etc.).</p>
                 *  <p>An example usage of a customized filterFunction is when text typed
                 *  is a regular expression and we want to display all the
                 *  items which come in the set.</p>
                 *  @example
                 *  <pre>
                 *  public function myFilterFunction(item:~~, text:String):Boolean
                 *     public var regExp:RegExp = new RegExp(text,"");
                 *     return regExp.test(item);
                 *  </pre>
                public function get filterFunction():Function
                    return _filterFunction;
                 *  @private
                public function set filterFunction(value:Function):void
                    //An empty filterFunction is allowed but not a null filterFunction
                    if(value!=null)
                        _filterFunction = value;
                        filterFunctionChanged = true;
                        dispatchEvent(new Event("filterFunctionChange"));
                    else
                        _filterFunction = defaultFilterFunction;
                //  filterFunction
                 *  @private
                 *  Storage for the keepLocalHistory property.
                private var _keepLocalHistory:Boolean = false;
                 *  @private
                private var keepLocalHistoryChanged:Boolean = true;
                [Bindable("keepLocalHistoryChange")]
                 *  When true, this causes the control to keep track of the
                 *  entries that are typed into the control, and saves the
                 *  history as a local shared object. When true, the
                 *  completionFunction and dataProvider are ignored.
                 *  @default "false"
                public function get keepLocalHistory():Boolean
                    return _keepLocalHistory;
                 *  @private
                public function set keepLocalHistory(value:Boolean):void
                    _keepLocalHistory = value;
                //  lookAhead
                 *  @private
                 *  Storage for the lookAhead property.
                private var _lookAhead:Boolean=false;
                 *  @private
                private var lookAheadChanged:Boolean;
                [Bindable("lookAheadChange")]
                [Inspectable(category="Data")]
                 *  lookAhead decides whether to auto complete the text in the text field
                 *  with the first item in the drop down list or not.
                 *  @default "false"
                public function get lookAhead():Boolean
                    return _lookAhead;
                 *  @private
                public function set lookAhead(value:Boolean):void
                    _lookAhead = value;
                    lookAheadChanged = true;
                //  typedText
                 *  @private
                 *  Storage for the typedText property.
                private var _typedText:String="";
                 *  @private
                private var typedTextChanged:Boolean;
                [Bindable("typedTextChange")]
                 *  A String to keep track of the text changed as
                 *  a result of user interaction.
                public function get typedText():String
                    return _typedText;
                 *  @private
                public function set typedText(input:String):void
                    _typedText = input;
                    typedTextChanged = true;
                    dispatchEvent(new Event("typedTextChange"));
                //  Overridden methods
                 *  @private
                override protected function commitProperties():void
                    super.commitProperties();
                      if(!dropdown)
                        selectedIndex=-1;
                    if(dropdown)
                        if(typedTextChanged)
                            cursorPosition = textInput.selectionBeginIndex;
                            updateDataProvider();
                            showDropdown = true;
                            selectedIndex = 0;
                            //In case there are no suggestions there is no need to show the dropdown
                              /* if(collection.length==0 || typedText==""|| typedText==null)
                                  dropdownClosed=true;
                                showDropdown=false;
                            else
                                selectedIndex = 0;
                 *  @private
                override protected function focusOutHandler(event:FocusEvent):void
                    super.focusOutHandler(event)
                     if(keepLocalHistory && dataProvider.length==0)
                         addToLocalHistory();
                 *  @private
                override public function getStyle(styleProp:String):*
                    if(styleProp != "openDuration")
                        return super.getStyle(styleProp);
                    else
                         if(dropdownClosed)
                         else
                             return 0;
                 *  @private
                override protected function keyDownHandler(event:KeyboardEvent):void
                    super.keyDownHandler(event);
                    if(!event.ctrlKey)
                        //An UP "keydown" event on the top-most item in the drop-down
                        //or an ESCAPE "keydown" event should change the text in text
                        // field to original text
                        if(event.keyCode == Keyboard.UP && prevIndex==0)
                             textInput.text = _typedText;
                            textInput.setSelection(textInput.text.length, textInput.text.length);
                            selectedIndex = -1;
                        else if(event.keyCode==Keyboard.ESCAPE && showingDropdown)
                            showingDropdown = false;
                        else if(event.keyCode == Keyboard.ENTER)
                            textInput.text = selectedLabel;
                            textInput.setSelection(cursorPosition, textInput.text.length);
                            textInput.setSelection(textInput.text.length,_typedText.length);
                        else if(lookAhead && event.keyCode ==  Keyboard.BACKSPACE
                        || event.keyCode == Keyboard.DELETE)
                            removeHighlight = true;
                     else
                        if(event.ctrlKey && event.keyCode == Keyboard.UP)
                     prevIndex = selectedIndex;
                 *  @private
                override protected function measure():void
                    super.measure();
                    measuredWidth = mx.core.UIComponent.DEFAULT_MEASURED_WIDTH;
                 *  @private
                override protected function updateDisplayList(unscaledWidth:Number,
                                          unscaledHeight:Number):void
                    super.updateDisplayList(unscaledWidth, unscaledHeight);
                    //down list otherwise changes the text in the text field to ""
                      if(selectedIndex == -1)
                        textInput.text = typedText;
                    if(dropdown)
                            //This is needed because a call to super.updateDisplayList() set the text
                            // in the textInput to "" and thus the value
                            //typed by the user losts
                              if(lookAhead && showDropdown && typedText!="" && !removeHighlight)
                                var label:String = itemToLabel(collection[0]);
                                var index:Number =  label.toLowerCase().indexOf(_typedText.toLowerCase());
                                if(index==0)
                                    textInput.text = _typedText+label.substr(_typedText.length);
                                else
                                    textInput.setSelection(cursorPosition, cursorPosition);
                                    removeHighlight = false;
                            else
                            typedTextChanged= false;
                        else if(typedText)
                            //Sets the selection when user navigates the suggestion list through
                            //arrows keys.
                            textInput.setSelection(_typedText.length,textInput.text.length);
                     if(showDropdown && !dropdown.visible)
                         //This is needed to control the open duration of the dropdown
                         super.open();
                        showDropdown = false;
                         showingDropdown = true;
                         if(dropdownClosed)
                             dropdownClosed=false;
                 *  @private
                override protected function textInput_changeHandler(event:Event):void
                    super.textInput_changeHandler(event);
                    //Stores the text typed by the user in a variable
                    typedText=text;
                //  Methods
                 *  @private
                 *  If keepLocalHistory is enabled, stores the text typed
                 *     by the user in the local history on the client machine
                private function addToLocalHistory():void
                    if (id != null && id != "" && text != null && text != "")
                        var so:SharedObject = SharedObject.getLocal("AutoCompleteData");
                        var savedData : Array = so.data.suggestions;
                        //No shared object has been created so far
                        if (savedData == null)
                            savedData = new Array();
                         var i:Number=0;
                         var flag:Boolean=false;
                         //Check if this entry is there in the previously saved shared object data
                         for(i=0;i<savedData.length;i++)
                            if(savedData[i]==text)
                                flag=true;
                                break;
                         if(!flag)
                             //Also ensure it is not there in the dataProvider
                             for(i=0;i<collection.length;i++)
                                 if(defaultFilterFunction(itemToLabel(ListCollectionView(collection).getItemAt(i)),text))
                                    flag=true;
                                    break;
                         if(!flag)
                             savedData.push(text);
                       so.data.suggestions = savedData;
                       //write the shared object in the .sol file
                       so.flush();
                 *  @private
                private function defaultFilterFunction(element:*, text:String):Boolean
                    var label:String = itemToLabel(element);
                    return (label.toLowerCase().substring(0,text.length) == text.toLowerCase());
                 *  @private
                 private function templateFilterFunction(element:*):Boolean
                    if(filterFunction!=null)
                        flag=filterFunction(element,typedText);
                    return flag;
                 *  @private
                 *  Updates the dataProvider used for showing suggestions
                private function updateDataProvider():void
                    dataProvider = tempCollection;
                     collection.filterFunction = templateFilterFunction;
                    collection.refresh();
                    //In case there are no suggestions, check there is something in the localHistory
                      if(collection.length==0 && keepLocalHistory)
                        usingLocalHistory = true;
                        dataProvider = so.data.suggestions;
                        usingLocalHistory = false;
                //  modified source
                 *  Closes the combox and set the selection which is lost using Flex 3
                 *  @event    Event    Trigger event to close the combobox
                  override public function close(event:Event = null):void
                    super.close(event);
                    if(selectedIndex == 0)
                        // set the text using the selected label
                        // select the text from typed text position to texts length
            • 3. Re: AutoComplete ComboBox
              I'm not going to debug your code for you.   Make your ode and/or question more specific.
              Yes, it is possible.  I've implemented two ways to do this in the Flextras AutoComplete, as stated in my previous answer.  Check it out; there are free development editions and I'm sure buying ours will be cheaper than building your own.
