When i try to load an existing SWF Module inside a Flex Tile using ModuleLoader/ModuleManager (mc:Tile) and trying to run the application using mosaic, I am getting the following error:
VerifyError: Error #1053: Illegal override of FlexModuleFactory in mx.core.FlexModuleFactory.
at global$init()
However, when i add the TileSDK.swc to the flex project and build the swf and load this swf inside inside a Flex Tile, the application works fine in mosaic.
But, i having a SWF provided by a third party for which i not having the source code and i want to load this inside a Flex Tile, but i am geeting the above error. Can u explain why this is happening and any workaround?
I also made the following observations:
Type of SWF to be loaded inside a Tile | With/Without SDK | Pass/Fail |
mx:Application | WITHOUT | Fail |
mx:Application | WITH | Fail |
mx:Module | Without | Fail |
Mx:Module | With | Pass |
Mc:ModuleTile | with | Pass |
Mc:Tile | with | Fail |
Thanks and Regards,
Shyam Sundar.A
ashok.shyamsundar@gmail.com
Views
Total Likes
Hello,
a Module Tile (.swc) needs to be compiled with the same version of the Flex SDK like the Mosaic framework. The current version Mosaic 9.0 is compiled with Flex SDK 3.4. Do you know if the SWF Module was compiled with SDK 3.4? Application tiles (.swf) can be compiled with different version of the Flex SDK (3.3 and 3.4).
We recommend to use Application tiles whenever possible and use Module tiles only as an exception (since Module tiles need to compiled with a specific version of the SDK).
Hope that helps,
Matthias Zeller
Views
Total Likes
