6 Replies Latest reply on Apr 9, 2010 5:31 PM by avdave
    Problem loading Image through XML!
    avdave
        I am Akshay and am beginner in this forum. I am trying to load images using flickr API and having problem.
      I am doing it in following fashion:
      1) I am calling the Httpservice to get the xml through flickr API as
      <s:HTTPService id="photoService" url="http://api.flickr.com/services/feeds/....FullAPI" resultFormat="e4x" result="photoResultHandler(event);" fault="photoFaultHandler(event);"/>
      2) In photoResultHandler I am retrieving the XML
      private function photoResultHandler(re:ResultEvent):void
      photoXml= re.result as XML;
      However, I am struggeling to retireve elements from photoXML and then use it to display image in :
      <mx:Image  id="img0" x="151" y="98" width="520" height="291"/>
      The XML structure is as below:
      <?xml version="1.0" encoding="utf-8" standalone="yes"?>
      <feed">
      <entry>
           <author>  </author>
           <link rel="enclosure" type="image/jpeg" href="http://farm5.static.flickr.com/4484460580_04bbced2d8_o.jpg"/>
      </entry>
      <entry>
      </entry>
      I need to load the href value of link  which can be found in feed-->entry-->link in the above xml.
      Please help!
      -Akshay
        • 1. Re: Problem loading Image through XML!
          dave cragg Level 2
          As an example:
              img0.source = photoXML.entry[0].link[0].@href
          That will set the source of Image  img0) to the href of the first link element of the the first entry element.
          • 2. Re: Problem loading Image through XML!
            avdave Level 1
            Thanks Dave,
               I tried that but in vain....the source= photoXML.entry[0].link[0].@href but actually not converting it to actual path on runtime I donno why
            I tried debbuging it and actually getting it value of source as null
            any thouhgts?
            -Thanks
            • 3. Re: Problem loading Image through XML!
              dave cragg Level 2
              I'm not sure what the problem is.
              Are you sure about the example XML structure you posted? Can you post a real example?
              I tried the url you posted, and although it redirected to a "not available" image, the redirected image displayed in the Image control.
              • 4. Re: Problem loading Image through XML!
                avdave Level 1
                Hello Dave,
                   Thanks for your prompt reply. Here's the mxml code :
                   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" creationComplete="photoService.send()"  minHeight="600">
                <fx:Script>
                <![CDATA[
                import mx.controls.Alert;
                import mx.events.FlexEvent;
                import mx.events.MoveEvent;
                import mx.rpc.events.FaultEvent;
                import mx.rpc.events.ResultEvent;
                [Bindable]
                public var photoXml:XML;
                //var src :int =  "{photoXml.feed.entry.updated}" as int;
                img0.source= String(photoXml.entry[0].link[1].@href);
                private function photoFaultHandler(fe:FaultEvent):void
                Alert.show(fe.fault.message);
                  </fx:Script>
                <fx:Declarations>
                <!-- Place non-visual elements (e.g., services, value objects) here -->
                <s:HTTPService id="photoService" url="http://api.flickr.com/services/feeds/photos_public.gne?id=48951865@N07" resultFormat="e4x" result="photoResultHandler(event);" fault="photoFaultHandler(event);"/>
                </fx:Declarations>
                </s:Application>
                Hope it helps you in finding out the problem...DO let me know your thouhgts
                Thanks again for your replies so far......
                -Akshay
                • 5. Re: Problem loading Image through XML!
                  Peter deHaan Level 4
                  I'm sure somebody can clean this up quite a bit, but this may help get you started. I think you're getting caught up by the default XML namespace:
                                 creationComplete="photoService.send();">
                      <fx:Script>
                          <![CDATA[
                              [Bindable]
                              public var photoXMLList:XMLList;
                              private function photoResultHandler(re:ResultEvent):void {
                                  var nsDefault:Namespace = new Namespace('http://www.w3.org/2005/Atom');
                                  default xml namespace = nsDefault;
                                  var tXML:XML = re.result as XML;
                                  photoXMLList = tXML.entry.link.(@rel == 'enclosure').@href;
                                  img0.source = photoXMLList[0];
                              private function photoFaultHandler(fe:FaultEvent):void {
                      </fx:Script>
                      <fx:Declarations>
                                         resultFormat="e4x"
                      </fx:Declarations>
                  </s:Application>
                  Peter
                  • 6. Re: Problem loading Image through XML!
                    avdave Level 1
                    Thanks Peter,
                       That's great help. This is exactly what I was looking for.
                       I am surprised though how the default namespace helped.
                    One last point, it's taking a while to load the image and I need loading around 15 images at a time .   If you can share your thoughts on this it would be great!
                    Thanks for your previous response again!
                    -Akshay
