3 Replies Latest reply on Apr 9, 2010 9:09 PM by webqaflash
    Actionscript stop / start command HELP required
    NathanBone
      Hi All,
      I am very new to actionscripting, so please forgive my low understanding of it at this time. I am putting together my first flash presentation and nearly go all my slides together. Within each slide I have animations and been able to create a simply 'stop' 'start' function usings elements as buttons.
      However, I want to achieve the same with a mouse or keyboard click, much in the same way Powerpoint works. I understand I need an event handler? I have tried to compose this code, but it does not work :@(
      Any tips would be greatfully received.
      Nathan
      stop ();
      // 1. Event handler function
      function clickHandler(event:KeyboardEvent.KEY_DOWN
      ) :void
      trace("SPACE");
      this._parent.nextFrame()
      // 2. Assign Listener
      a.addEventListener(KeyboardEvent.KEY_DOWN
      , clickHandler);
        • 1. Re: Actionscript stop / start command HELP required
          webqaflash Level 3
          This will help you
          var myListener:Object = new Object();
          myListener.onKeyDown = function () {
              switch (Key.getCode()) {
                  case Key.SPACE :
                      trace("space");
                      break;
                  case Key.LEFT :
                      trace("left");
                      break;
                  case Key.UP :
                      trace("up");
                      break;
                  case Key.RIGHT :
                      trace("right");
                      break;
                  case Key.DOWN :
                      trace("down");
                      break;
          myListener.onKeyUp = function () {
              trace ("You released a key.");
          Key.addListener(myListener);
          • 2. Re: Actionscript stop / start command HELP required
            NathanBone Level 1
            Hi Fella,
            Thanks for that, sorry I know I am going to sound really dumb here, do I add this to the original code I have, or removed everything and just put your new code? Tried both, neither seems to work
            Basically what I am trying to achieve is that I have 3 slides that I am trying to link together a bit like a power point presentation, within each slide there is a series of bullet points that are animated, I have labelled each animation: a, b, c, etc.
            What I am trying to achieve is that in between each animation, the animation stops, then on a keyboard click or mouse click, the animation resumes until the next 'Stop' command.
            I was able to get the 'stop' and 'play' command to work by setting each animation as buttons, that when hit prompted the animation. I did this by using this code:
            stop ();
            d. onKeyDown = function() {
            But as the end product I want to create is in effect a powerpoint presentation set in flash, I need to learn how to use the keyboard or mouse to do the same.
            Any ideas???
            Many Thanks
            Nathan
            • 3. Re: Actionscript stop / start command HELP required
              webqaflash Level 3
                      case Key.SPACE :
                         //put your actions here for the space button.
                          break;
                      case Key.LEFT :
                          //put your actions here for the left button.
                          break;
                      case Key.UP :
                          //put your actions here for the up button.
                          break;
                      case Key.RIGHT :
                           //put your actions here for the right button.
                          break;
                      case Key.DOWN :
                           //put your actions here for the downbutton.
                          break;
