2 Replies Latest reply on Apr 22, 2010 4:19 AM by Karthik@Chennai
    Regarding Tree sort
    Karthik@Chennai
      Hi All,
      How to sort  a tree which contains Multilevel node  XMLList collection as dataprovider.
      Note :I have tried with XMLList collection sort functionality but able to do sorting for first level iam struck child level recursively...
      regards,
      karthik
        • 1. Re: Regarding Tree sort
          Flex harUI Adobe Employee
          There is no support for that in Tree. There is some support in
          AdvancedDataGrid so you can try it there.
          • 2. Re: Regarding Tree sort
            Karthik@Chennai Level 1
            Hi All,
            I have solved the sorting issue by keeping the child items in a separate clone copy as XMLList collection and updated to the original dataprovide by delete and inserting node freshly.For ur reference i have attached the code
            private function sortTree(selectedItemNode:XML):void
            var i:int;
            var serverNodeList:XMLList = selectedItemNode.children();
            var newColl:XMLListCollection = new XMLListCollection(selectedItemNode.children());
            var sortList:Sort = new Sort();
            //this block of codes to remove the childrens of the selected node
            for(i = 0; i < serverNodeList.length(); i++)
              delete serverNodeList[i];
              i--;
              if(serverNodeList[i].children().length() > 0)
               sortTree(serverNodeList[i]);
            sortList.fields=[new SortField("@label", true, false)];
            newColl.sort = sortList;
            newColl.refresh();
            //this block of codes to add the childrens under the selected node
            for(i = 0; i < newColl.length; i++)
              selectedItemNode.appendChild(newColl[i])
            regards,
            karthik
