0 Replies Latest reply on Apr 9, 2010 5:29 AM by g_weber
    convert3dFromXML Example?
    g_weber Level 1
      Hi
      does anybody have an example on the usage of the Generate3dPDFClient.convert3dFromXML function?
      I have a Java program that calls this function via RMI to create a 3D PDF from some CAD parts (Pro/E). The LiveCycle stuff seems to work, but the A3DReviewer.exe on the server host crashes with the following entry in the Windows Event Log:
      Die Anwendung "C:\PROGRA~2\Adobe\ACROBA~1.0\Acrobat\PLUG_I~1\prc\A3DREV~1.EXE" hat einen Programmfehler verursacht. Datum und Zeit des Fehlers: 08.04.2010 um 16:14:48.268 Ausnahme: 80000007 an Adresse 00000000 (ntdll!ZwWaitForMultipleObjects)
      The conversion log ends with:
      2010/04/08 15:32:06 <I> Loading xml assembly structure from file C:\Adobe\ES2_Temp\pdfg-Administrator\e7\9e77-85afbd-ce3217-d0f02d-7dc46f-96ff53\asm.xml
      2010/04/08 15:32:06 <I> Parsing xml assembly structure ...
      2010/04/08 15:32:06 <I> Read part file C:\Adobe\ES2_Temp\pdfg-Administrator\e7\9e77-85afbd-ce3217-d0f02d-7dc46f-96ff53\something .prt
      2010/04/08 15:32:06 <I> Read part file succeeded.
      2010/04/08 15:32:06 <I> Plug part file ended with success.
      2010/04/08 15:32:06 <I> Conversion to PDF...
      The CAD parts in question can be converted to 3D PDF via LiveCycle without problems. I tried to feed the convert3dFromXML the PDF files instead of the CAD files, but that did not change anything.
      Any help appreciated
        Guido
