4 Replies Latest reply on Sep 16, 2007 5:20 PM by Anti-Girl
    datagrid dataprovider = string?
    Anti-Girl Level 1
      can a datagrids, data provider not read from a string?
      [Bindable] public var connectionType:String = new String("connection.lastResult.results.record");
      <mx:DataGrid id="myDataGrid" dataProvider="{connectionType}................
      this wont work,
        • 1. Re: datagrid dataprovider = string?
          Senor_Roberto
          Data providers need to be an ArrayCollection or XMLListCollection.
          In your example, it's not clear what you're trying to achieve.
          Are you trying to cast every record in lastResult.results.record to a String and bind that to the DataGrid?
          • 2. Re: datagrid dataprovider = string?
            Anti-Girl Level 1
            Well i have 2 httpservices, and one datagrid, i was hoping i could change the dataprovider depending on which one is called.
            so i thought maybe i could call a string and change that when needed
            • 3. Re: datagrid dataprovider = string?
              Senor_Roberto Level 1
              Well, you can change the dataProvider easily enough, but it's still unclear what you're intentions are.
              You're binding a single string, not an array of data.
              Are you trying to bind the record? i.e.:
              [Bindable]
              public var connectionType:ArrayCollection = connection.lastResult.results.record;
              • 4. Re: datagrid dataprovider = string?
                Anti-Girl Level 1
                i dont think that worked, got error saying cannot convert to array etc, i had imported array util aswell,
                anyway i figured it out, i just added result="dataHandler()" to my HTTPSERVICE
                and then
                public function dataHandler():void
                myDataGrid.dataProvider = connection.lastResult.results.record;
                ____________________________________________
                i have 2 http servies, id connection1 and connection2,
                connection.lastResult.results.record; = displays result in datagrid
                i wanted to use the SAME datagrid to display connecion2's result BUT not at the same time, etc etc
                thanks alot for ur time
