1 Reply Latest reply on Oct 10, 2006 6:58 AM by foozebox
    Help required with writing an xml parser function
    BuzzF
      Hi guys
      I'm trying to write a function that will parse through an xml document and store the contents into variables,
      I can write it by using lots of for and if loops (which is a lot of code if there are lots of nodes) however i'm pretty sure there's a really neat and concise way of writing it in a function call that calls itself if there are childNodes, but I can't get my head around the logic,
      Can anyone give me some suggestions as to how to write such a function?
      Here is some example code which i'm using at the moment....
      //check for child nodes for node 1
      for (i=0; i<this.childNodes.length; i++) {
      _root["node"+i+"Name"] = this.childNodes .nodeName;
      _root["node"+i+"Value"] = this.childNodes
      .nodeValue;
      //check for child nodes for node 2
      if (this.childNodes .hasChildNodes()) {
      for (j=0; j<this.childNodes
      .childNodes.length; j++) {
      _root["node"+i+"."+j+"Name"] = this.childNodes .childNodes[j].nodeName;
      _root["node"+i+"."+j+"Value"] = this.childNodes
      .childNodes[j].nodeValue;
      //check for child nodes for node 3
      if (this.childNodes .childNodes[j].hasChildNodes()) {
      for (k=0; k<this.childNodes
      .childNodes[j].childNodes.length; k++) {
      _root["node"+i+"."+j+"."+k+"Name"] = this.childNodes .childNodes[j].childNodes[k].nodeName;
      _root["node"+i+"."+j+"."+k+"Value"] = this.childNodes
      .childNodes[j].childNodes[k].nodeValue;
      Is it possible to convert this code into a concise function that will call itself if there are any childNodes?
      Many thanks for your responses :-)
