1 Reply Latest reply on Sep 13, 2007 4:32 PM by Senor_Roberto
    Flex equivalent to WPF IValueConverter?
    jemiller0
      Hi all,
      In WPF, you can implement an interface named IValueConverter which has Convert() and ConvertBack() methods which convert a value from an object to a string and vice versa. JSF has something similar. I want to do in Flex what is done in the example in the following document.
      http://msdn2.microsoft.com/en-us/library/system.windows.data.ivalueconverter.aspx
      Namely, I want to bind a Date to a TextInput. However, I don't want to use the default toString() and parse() conversions. I want to be able to customize the format that the date is displayed in in the TextInput. Then, I want to be able to parse it back into a Date.
      I see that you can use BindingUtils to specify a setter function. However, I need a getter function too. Can I do this in Flex?
      Jon
        • 1. Re: Flex equivalent to WPF IValueConverter?
          Senor_Roberto
          I have done a similar thing but I couldn't find anything in Flex which is the equivalent.
          I ended up building a decorator object with public getter/settor mutator method for a property called 'value'.
          I then bound object.value instead of just the property.
          In the case of a date:
          public class DateDecorator {
          private var _realdate:String; // or whatever
          public function set value (date:String) : void {
          // Convert to internal value
          public function get value () : String {
          // Convert to external value
          Then:
          var dd:DateDecorator = new DateDecorator();
          And bind the value property, {dd.value}
