3 Replies Latest reply on Apr 16, 2010 10:32 AM by Xavier Agnetti
    fail on error?
    acastrucc Level 1
      I'm wondering if, like pmd, flexpmd has a notion of fail.on.error setting?
      i.e. using ant to invoke pmd I might do
      <antcall target="pmd">
                  <param name="fail.on.error" value="false"/>
      One might want to have a daily build fail on flexpmd errors etc.
        • 1. Re: fail on error?
          Xavier Agnetti Adobe Employee
          Yes there is one: failOnError
          You should be good to go with that.
          • 2. Re: fail on error?
            Hi Xavier,
            We've been using failOnError with some degree of success, but there is a problem..
            This parameter causes the build to fail immediately. As a result the xslt transformation task to generate the report of the failing run isn't executed.
            We'd rather fail the build in a similar way to the way we fail our flexUnit run, by setting a fail task up at the end of our macrodef:
            <fail if="flexPMD.failed" message="PMD failed - check reports"/>
            But this would obviously require flexPMD to populate some kind of environment variable with its status.
            Is this possible at the moment?
            kind regards,
            • 3. Re: fail on error?
              Hi Espen,
              No it is not possible at the moment.
              Feel free to create a enhancement for that.
