1 Reply Latest reply on Apr 9, 2010 2:28 PM by reppert
    Indesign and xsl not cooperating
    reppert
      Got a new problem with importing xml with xsl into a table in indesign.
      The job works when I use oxygen to make a new xml file from the xml/xsl files.
      Problem is I want to bypass oxygen and have indesign do it on its own.
      XML:
      <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
      <Root>
          <Story>
              <TableSection xmlns:aid="http://ns.adobe.com/AdobeInDesign/4.0/" aid:table="table"
                  aid:trows="2" aid:tcols="6">
                  <SectionCode aid:table="cell" aid:theader="" aid:crows="1" aid:ccols="1"
                      aid:ccolwidth="30.908648796453704">01</SectionCode>
                  <SectionName aid:table="cell" aid:theader="" aid:crows="1" aid:ccols="5"
                      >FRAME</SectionName>
                  <Code aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="30.908648796453704"
                      >PD</Code>
                  <ItemNum aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="100.42931416650917"
                      >IN054B</ItemNum>
                  <Vendor aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="78.3">ALI ARC
                      (AN)</Vendor>
                  <Description aid:table="cell" aid:crows="1" aid:ccols="1"
                      aid:ccolwidth="167.39999999999998">AliArc 92/9400 Bumper &apos;97 &amp;
                      Up</Description>
                  <Price aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="71.56323531584569"
                      >$2,350.00</Price>
                  <Photo aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="90.39880172119148">
                      <Picture
                          href="file:///Y:/M/Maxim/Parts%20Catalog/Design/Indesign/TIRE%20CHAINS%20(NEW%20PARTS).jp g"
                  </Photo>
              </TableSection>
          </Story>
      </Root>
      XSL:
      <?xml version="1.0" encoding="UTF-8"?>
      <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
          xmlns:xd="http://www.oxygenxml.com/ns/doc/xsl" version="1.0">
          <xsl:output method="xml" omit-xml-declaration="no" indent="yes" encoding="US-ASCII"/>
          <xsl:decimal-format name="money" digit="D"/>
          <xsl:key name="SectionKey" match="Story" use="SectionName"/>
          <xsl:template match="/">
              <Root>
                  <Story>
                      <xsl:for-each
                          select="//Story[generate-id(.)=generate-id(key('SectionKey',SectionName))]">
                              aid:table="table" aid:tcols="6">
                              <xsl:attribute name="aid:trows">
                                  <xsl:value-of select="TableRows"/>
                              </xsl:attribute>
                                  <xsl:value-of select="SectionCode"/>
                              </SectionCode>
                              <SectionName aid:table="cell" aid:theader="" aid:crows="1" aid:ccols="5">
                                  <xsl:value-of select="SectionName"/>
                              </SectionName>
                              <xsl:for-each select="key('SectionKey',SectionName)">
                                      <xsl:value-of select="Code"/>
                                  </Code>
                                      aid:ccolwidth="100.42931416650917">
                                      <xsl:value-of select="ItemNum"/>
                                  </ItemNum>
                                      <xsl:value-of select="Vendor"/>
                                  </Vendor>
                                      <xsl:value-of select="Description"/>
                                  </Description>
                                      aid:ccolwidth="71.56323531584569">
                                      <xsl:value-of select="format-number(Price,'$D,DDD,DD0.00','money')"
                                  </Price>
                                      aid:ccolwidth="90.39880172119148"> Picture </Photo>
                              </xsl:for-each>
                          </TableSection>
                      </xsl:for-each>
                  </Story>
              </Root>
          </xsl:template>
      </xsl:stylesheet>
      Last is the Oxygen xml file it makes that works in indesign, but cant get indesign to make on its own.
      Thanks for any help.
        • 1. Re: Indesign and xsl not cooperating
          reppert Level 1
          <?xml version="1.0" encoding="US-ASCII"?>
          <Root xmlns:xd="http://www.oxygenxml.com/ns/doc/xsl">
             <Story>
                <TableSection xmlns:aid="http://ns.adobe.com/AdobeInDesign/4.0/" aid:table="table" aid:tcols="6" aid:trows="4">
                   <SectionCode aid:table="cell" aid:theader="" aid:crows="1" aid:ccols="1" aid:ccolwidth="30.908648796453704">01</SectionCode>
                   <SectionName aid:table="cell" aid:theader="" aid:crows="1" aid:ccols="5">FRAME</SectionName>
                   <Code aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="30.908648796453704">PD</Code>
                   <ItemNum aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="100.42931416650917">IN054B</ItemNum>
                   <Vendor aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="78.3">ALI ARC (AN)</Vendor>
                   <Description aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="167.39999999999998">AliArc 92/9400 Bumper '97 &amp; Up</Description>
                   <Price aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="71.56323531584569">$2,350.00</Price>
                   <Photo aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="90.39880172119148"> Picture </Photo>
                   <ItemNum aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="100.42931416650917">IN064F</ItemNum>
                   <Description aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="167.39999999999998">AliArc 9900 Bumper</Description>
                   <Price aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="71.56323531584569">$2,261.95</Price>
                   <ItemNum aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="100.42931416650917">IN064T</ItemNum>
                   <Description aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="167.39999999999998">AliArc 9900 Bumper Texas</Description>
                   <Price aid:table="cell" aid:crows="1" aid:ccols="1" aid:ccolwidth="71.56323531584569">$2,800.51</Price>
                </TableSection>
          ETC.........
          forgot to paste
