4 Replies Latest reply on Sep 18, 2007 11:30 AM by Trugriff
    Application Scope
    Trugriff
      Hi:
      I defined a variable in my MXML Application file that retrieves an array from a ColdFusion Page. It is a list that will be used visually and non-visually throughout the application. It is in a database so I don't have to hard-code values...just query database and retrieve list...which works...list (array) is populated and ready to use.
      I have a private array variable in a custom component that I want to assign the value of the application level array...but it gives me an error each time.
      MXML file:
      [Bindable]
      public var colorList:ArrayCollection;
      Custom Component File:
      import mx.core.Application;
      private var lstColors:ArrayCollection;
      lstColors = Application.application.parameters.colorList;
      results in
      1120: Access of undefined property lstColors.
      What am I missing?
      Thanks!
        • 1. Re: Application Scope
          Level 7
          Try this
          private var lstColors:ArrayCollection = new ArrayCollection();
          Rgds
          JFB
          "Trugriff" <rjones@solarcc.com> wrote in message
          news:fcmmcn$8ur$1@forums.macromedia.com...
          > Hi:
          > from
          > non-visually
          > hard-code
          > (array) is
          > assign
          > time.
          > MXML file:
          > [Bindable]
          > results in
          > What am I missing?
          > Thanks!
          • 2. Re: Application Scope
            Trugriff Level 1
            OK:
            When I bind my resultset (returned from ColdFusion), the event.result has the proper length but when I go to assign it to my ArrayCollection typed variable and cast it as an Array, the length after the assigment is 0 and I lose the resultset.
            [Bindable]
            public function colorListReturn(event:ResultEvent):void
            trace(event.result.length); //returns 9
            colorList = new ArrayCollection(event.result as Array);
            trace(colorList.length); //RETURNS 0
            Why would it wipe out the resultset?
            Rhys
            • 3. Re: Application Scope
              Level 7
              Try this
              [Bindable]
              public var colorList:ArrayCollection = new ArrayCollection;
              colorList = ArrayCollection(event.result);
              Do you see? You are initializing the array in your fuction... I hope this
              help
              RGDS
              JFB
              news:fcoik1$dg3$1@forums.macromedia.com...
              > OK:
              > the
              > variable
              > the
              > resultset.
              > [Bindable]
              > Thanks,
              > Rhys
              • 4. Re: Application Scope
                Trugriff Level 1
                worked...thanks for the info...
