3 Replies Latest reply on Sep 17, 2007 2:11 PM by SymTsb
    Error #2101
    L Z
      Hello Adobe Actionscript community,
      Im having a migrating problem of how to send variables to a php. The application is working, but, on Internet explorer, outputs the following error message:
        • 1. Re: Error #2101
          SymTsb Level 2
          This error should be showing up in the Flash test environment as well. This means one of two things. The first is that there is an actual problem with the echo statement you are sending back to Flash (assuming that you want to capture data after your php file has processed it. The second is a problem with the properties of the corresponding URLVariables object used to catch the return data. I've attached an example of valid working code (sends an e-mail) and includes both the PHP code and the Flash AS3 on the main timeline.
          • 2. Re: Error #2101
            L Z Level 1
            Man I dont believe... You helped me A LOT. I did a series of side-by-side tests, and discovered that, in my case, the cause of the whole problem was that my php does not echo nothing. Strange hun? Now it works very very fine. Thanks!
            • 3. Re: Error #2101
              SymTsb Level 2
              You're very very welcome.
