0 Replies Latest reply on Apr 10, 2010 7:58 AM by nbcaldwell
    Wow!  Works when moving JS files too!
    nbcaldwell
      Just discovered the procedure I described in "Move PHP files . . . - site relative paths - don't work"  (well, they do, just have to tweak them)
      Just discovered it works also when you move files containing JavaScript that references links in the JS text.  They break (don't work) when you move a file into a subfolder.  All other document and site root relative links update (if you use File Panel to make the move)
      Following exact same procedure for SSI called files works for the JS links as well.  They perform beautifully.
