1 Reply Latest reply on Apr 10, 2010 9:51 AM by the_wine_snob
    PE7, The pics will slide from right to left consecutively but no zoom in??
    OGUL BALCI
      Hi all,
      Is this possible with PE7!
      30 pics. All 1920 x 1080. Horizontal.
      I want to make a video that these pics will slide consecutively from one side to another!!??
      But will not zoom during that time!!
      Once upon a time I had trial version of Imaginate 2.0! I miss it! Any similar program that you can advise??
      Thanks in advance!
        • 1. Re: PE7, The pics will slide from right to left consecutively but no zoom in??
          the_wine_snob Level 9
          Yes. You can Keyframe the fixed Effect, Motion>Position over the Duration of each image. If all are the same size, and you wish to apply the exact set of Keyframes to each, that is easy too. First, just set up your Keyframing in the first to suit. Then, Rt-click on that Clip, and choose Copy. Now, lasso all other Clips, Rt-click and choose Paste Attributes to animate each of those as well.
          PrE might have an animation Preset to do similar, but I always animate via Keyframes, so that I have 100% control. You might also want to explore some of the Transitions, as what you want just might be available there too.
